Backhoe DK55/45C and backhoe
   / DK55/45C and backhoe #1
Goalnightx
I know that you can now buy the backhoe for a DK55 but is the subframe pretty strong and how easy is it to take off and use regular 3pt attachments? Thanks
   / DK55/45C and backhoe #2
I have seen the DK55 with Backhoe and there are only two pins to remove, disconnect hoses and drive away. It was very easy. John
Thanks John. Did it look like the 3pt was useable after that or did the subframe appear to be in the way?
   / DK55/45C and backhoe #4
<font color="blue">Did it look like the 3pt was useable after that or did the subframe appear to be in the way? </font>
The remaining subframe that the Bh attaches too is minimal and has no effect on the 3pt operation.
   / DK55/45C and backhoe #5
I have the Dk45 witha 2385 sub frame mount and it is very easy to chage out . 2 pins and disconnect the hoses ! /forums/images/graemlins/smile.gif It does not interfer with any of my 3 pt attachments. I have also owned a 3 pt. mount backhoe on a Kubota and it was a royal pain to remove . I kept bending pins and then I would end up using a cutting torch to remove them /forums/images/graemlins/frown.gif. I guess it was just to much weight on the 3/4 pins .
Big Al
   / DK55/45C and backhoe #6
Goalknightx, You have the answer, now go get you one! John
   / DK55/45C and backhoe #7
Goalnightx, I have the subframe instock if you want any pictures or I can show you the mounting instructions if you are interested /forums/images/graemlins/grin.gif
   / DK55/45C and backhoe #8
Goalnightx, sorry I misspelled your name in the earlier post, guess you'll be a KNIGHT on that new Kioti you're going to buy. Or at least feel like a charging one. /forums/images/graemlins/grin.gif We're all Knights of the Kioti! John
2015 TRANSMASTER LOWBOY TRAILER (A51222)
2015 TRANSMASTER...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
Komatsu PC490LC-11 Hydraulic Excavator (A49346)
Komatsu PC490LC-11...
2016 John Deere TS Gator Utility Cart (A48082)
2016 John Deere TS...
