dk55 and Woods backhoe BH90-X or 1050
   / dk55 and Woods backhoe BH90-X or 1050 #1
robintexas
Cleburne, Texas
Kioti DK55
Does anyone have a DK55 or higher tractor and a woods backhoe either a 3 point or sub frame? If so what are your opinions of the woods backhoe and would you recommend the woods over the kioti equivalent. The models being considered are the BH90-X and the 1050. It may not be commensurate to say a comparison as few people would buy one then go buy the other, but if you bought the woods models have you been pleased with them. This is mostly a cost to quality comparison issue.
   / dk55 and Woods backhoe BH90-X or 1050 #2
The largest you could get with the Kioti is the 8-1/2
Woods you can do the 90x.
Now depending on what loader you have on your DK55 will tell you if you can do a Woods backhoe. The old 1595 loader is compatible with the Woods sub frame but the new Kioti Kl551 loader is not with out modifying the frame.
I would never put a 3pt backhoe on!
The Woods 90X is twice the backhoe of the Kioti KB2485
There in lies the question. I have the KL551 FEL I want to use the sub frame mount for the BH90-X and I did not understand if there would be compatibility or fitment issues between my current sub frame for the KL551 and what would be needed for the BH90-X. Does the BH90-X sub frame replace what I am using with the KL551 FEL or just augment it? The Woods sub frame is PN 1009701 with a Kioti KL1595 FEL compatibility. Was there any design change or was the KL1595 designed for the larger Kiotis?
Thanks in advance for any info.
Rob
Edit: After reading Ricks response my question should be would the KL1595 sub frame replace the one I have and is it worth all the engineering or should I be happy with a smaller BH?
Hydraulic Hose Reel (A49461)
Hydraulic Hose...
2019 CATERPILLAR 930M WHEEL LOADER (A51242)
2019 CATERPILLAR...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 FORTITUDE MANUFACTURING 40X96 FLATBED (A50854)
2008 FORTITUDE...
2025 Unused International MV607 Truck TMA Attenuator Truck (A49461)
2025 Unused...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
