Do I need to use Permatran?
   / Do I need to use Permatran? #1
JK10MF1635
Northwest CT
Massey Ferguson 1635
I am wondering if I can use another brand to top off my 1635 hydralics? I would like to top it off but don't have any Permatran on hand and the closest dealer is over an hour away. The local new holland dealer is 5 mins away and says I can use any brand in the tractor and mixing is fine as well. Any thoughts on this? Thanks
   / Do I need to use Permatran? #2
I would use the Permatran Oil as using other oil could void warranty is something was to go wrong. My dad went to our Massey dealer 30-40minutes away and bought 2, 5 gallon pails of the oil so we always have it on hand. If you have any dealers close that sell tractors that are part of the Agco family they should have the oil.
   / Do I need to use Permatran? #3
I wouldn't mix different oils......
Massey's appear to be touchy.
EDIT: A few on here have switched to synthetic and have had success. 99% of the post I've seen here on TBN, have had failures from using 'dino-oil' other than permatran, and have had failures............with that track record I will stick with Permatran, or synthetic.
   / Do I need to use Permatran? #4
Here is my take.
This experience is strictly with the GC series.
It's not these MF products that are touchy. It's the fact that some generic fluids are of poor quality.
About half of those who tried any of the various universal generic trans fluids have reported some sort of issue with it, usually minor.
People who use a quality brand name product, such as the Kubota or Case fluid, have not reported any problems.
About half of us are using Amsoil synthetic, no one has reported any issue with it.
The other half are mostly using Permatran.
You probably will be fine if you use a premium New Holland fluid, but I have not heard of anyone using it.
   / Do I need to use Permatran? #5
They cannot void warranty. If there is a repair, and you did not use permatran, they will charge you for the oil when they refill it...BTDT!
   / Do I need to use Permatran? #6
Yep, if the product you use, meets the spec's in the manual, it's a binding legal contract.
By Federal law, warrantors cannot require that only branded parts be used with the product in order to retain the warranty.
The kind of failures that are going to happen during the warranty period are usually going to be failures of hard parts, due to manufacturing defects. They don't tend to need a debate to determine the cause.
   / Do I need to use Permatran? #7
I just went through the same senario with my 50 hour fluid change and elected to drive the 1.5 hours to the nearest Massey dealer for the Permatran, there were enough stories of problems posted on TBN that scared me into using permatran only. The way I look at it is that it is cheap insurance...if you used cheaper fluid and did have a problem, now your gonna have to drive an hour pulling a tractor and coming home with an empty trailer.
   / Do I need to use Permatran? #8
We had the left brake arm seal spring a leak with 10 hours on Petro Canada Duratran synthetic. Not sure if it was bad luck? Now I am leary of running anything but Permatran. Duratran is a top notch product too, huge in logging.
   / Do I need to use Permatran? #9
I use the NAPA hydraulic oil that is labeled for Permatran III
   / Do I need to use Permatran? #10
Seals leak with permatran too.
I would not bet it was the fluid.
Permatran is really good stuff. I switched my fairway mower to it, and there is a noticeable difference in the temperature it runs at.
   / Do I need to use Permatran? #11
Do you guys feel like the manufactures brand oil requirements are a scam? I am a Kubota guy and they push their product heavily and it sounds like MF does also. After being around heavy equipment for years I have seen different contractors use different oils for many years without any noticeable performance or longevity issues. I have about come to the point where I think it is just another way to make a buck for the company. If the oil meets the recommended specs I think it all came from the same dinosaur.
MarkV
   / Do I need to use Permatran? #12
Do you guys feel like the manufactures brand oil requirements are a scam? I am a Kubota guy and they push their product heavily and it sounds like MF does also. After being around heavy equipment for years I have seen different contractors use different oils for many years without any noticeable performance or longevity issues. I have about come to the point where I think it is just another way to make a buck for the company. If the oil meets the recommended specs I think it all came from the same dinosaur. MarkV
If you read the thread, you should not have to ask that.
We are talking hydraulic transmission oil here, it has to do lots of different things, including braking.
Oil is oil. But, the additives they put in it are the difference. Your not going to get a top shelf additive package, in a bargain product. Some owners have found that out with noticeable performance differences. Though some did report they were satisfied.
For our machines, you need less than 5 gallons. In my opinion, it's foolish to even consider using cheap fluid. You can't save enough money to make it worth while. Permatran is not that much more money.
Premium products can also exceed the manufacturers specifications.
   / Do I need to use Permatran? #13
MarkV
My dealer mentioned several different hydraulic oils that I could use to save money. I told him that I felt more comfortable using the Permatran.
But back to the OP's original question..........I'm still not so sure about mixing different brands to top the machine off.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
2003 Big Tex 10PI...
