Do you have favorite brush cutters because of gear noise?
   / Do you have favorite brush cutters because of gear noise? #1
JimRB
Veteran Member
Covington, GA
JD 870
I got a JD 513 brush cutter years ago that has rusted out, been patched, and rusted out again. I was not wanting to spend the time making a new deck so I picked up a Titan 60" cutter. The JD has a gearbox oil filled. The Titan box is grease filled. The Titan box is louder than the JD box. Is that cut of the gears or does oil filled quiet things down? Yes, the grease level seems to be ok.
I will eventually get a new deck bent and I will finish welding on all the other steel for the JD just because it is quieter and the design does a better job breaking up horse manure than the Titan.
   / Do you have favorite brush cutters because of gear noise? #2
I wear radio muffs and dont notice any of it.
   / Do you have favorite brush cutters because of gear noise? #3
I can't hear the gears on my LP 60" cutter. I am surprised that you can hear them on yours over the tractor engine.
   / Do you have favorite brush cutters because of gear noise? #4
My 5' KingKutter just has a quiet pulsing hum. I am actually surprised how quiet it is.
   / Do you have favorite brush cutters because of gear noise? #5
I have never heard gear noise on any of the many cutters I have had. Some grease filled some oil.
With the noise of the blades, and tractor.....If you can hear the gears over that I'd be surprised
   / Do you have favorite brush cutters because of gear noise? #6
I had the gear box on one of my Woods rotary cutters get VERY loud one time, it was the day it went completely out of oil!! I came home, put oil in it and it quieted right down, but in about an hour or so, I checked it and it was empty again!
From that day on, I've put grease in that box and I've never heard another peep out of it again, and THAT was many MANY years ago. That gear box today is just fine, but the rest of the cutter looks like junk!!
One of these days, I'm going to go buy a Woods medium duty Brush bull, as Woods rotary cutters have been the BEST cutters I've ever owned or even used.
SR
   / Do you have favorite brush cutters because of gear noise? #7
My BH286 has a very quiet gearbox. The cutter noise is mostly blade "whirr". Partly because I've been happy with my BH, I recommended a smaller 5 ft. BH to my FIL (forgot the exact model). From day one, the gearbox has been horrendously noisy! It started out oil-filled; after the first season, oil was gone. I assume he ran over some wire and ate the gearbox seal. Rather than replace the seal, he refilled with cornhead grease. I assumed that would quiet it down. NOT! Still just as noisy.
   / Do you have favorite brush cutters because of gear noise? #8
I don't use any spl. grease in the gear box on mine, I use the cheapest grease I can get, it all works just fine.
As the gear box heats up, any grease in there will flow plenty good enough to lube the bearing ect...
SR
   / Do you have favorite brush cutters because of gear noise? #9
My country line box cannot be heard over the tractor engine. There is noticeable noise from the blades at start up for a second until they get up to speed. After that you hear the blades turning but not the gear box.
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2017 Ford F-250 Ext. Cab Pickup Truck (A50323)
2017 Ford F-250...
2015 Volkswagen Passat SE Sedan (A50324)
2015 Volkswagen...
2008 Peterbilt 389 Tandem Axle Road Tractor (A47384)
2008 Peterbilt 389...
2009 Ford F-550 4x4 11ft Flatbed Truck (A50323)
2009 Ford F-550...
