does anyone own one of these and does it work
   / does anyone own one of these and does it work #1
sam5570
Veteran Member
south west virginia
new holland tn70
I am looking at this dianostic tool called the [CAR DR] just need some imput on weather it works or just another gimmic
   / does anyone own one of these and does it work #2
It's just a code reader. Save your money.
thanks so much no scan just code that not good
   / does anyone own one of these and does it work #4
Most scan tools like this are simply that. They are a tool that will scan you vehicle and list any trouble codes. Most codes can be cleared by the tool as well. They give you an idea where to look for repairs. Some codes cannot be cleared and will require a trip to the dealer to have the part replaced and code cleared. There are many code readers on the market for $100 or less. Most auto parts stores will even use their scan tool to read your trouble codes for free.
There is a big difference between a $100 scan tool and a multi thousand dollar diagnostic computer a dealer or repair shop uses.
A scan tool can save you money if you have automotive knowledge. I have an Actron scan tool myself. It reads and can reset many codes. It gives me a starting point of where to look if the check engine light comes on and many times I can replace the part and reset the code saving me hundreds of dollars over what a garage or dealer would charge. It all depends on what codes come up whether I should tackle it or not.
George i know where you comming from i was in the auto repair business for long time i have a mac pro link system that worked well in it;s day but it only went to 1995 my problem is i worked behind all the dealers and so called machanic's for so many years i just don't trust them so i am always keeping a eye out for something to by pass them i have no problem doing the work i just need the scanner to give me ideal where to start i refuse to do like most people and use trail and erea it's just to expensive thanks for info
   / does anyone own one of these and does it work #6
I have used code readers before,at least a place to start.I have used mine on a number of vehicles.
   / does anyone own one of these and does it work #7
I have an actron scanner as well. I can't remember the model, but it was around $160 and will read some live data. It also does some OEM codes not found on generic scanners. It is okay, but would like a little more. Autoenginuity seems interesting, but not sure about real world effectiveness. I have also thought about a OTC genesys for a little more money. Have heard good things about the OTC and it is the same as the Matco determinator. Another PC based one that costs more is AutoEase (I think).
you know otc has been around sense the 70's maby before but i have alot of there manuals on the early 80's ford and they were a great help to me finding problems they are very in depth on there info the manuals run from 81 to 93
   / does anyone own one of these and does it work #9
I realize they have been around for a while, but from what I see their tools aren't what they used to be. Mostly stuff outsourced to Asia now, sure doesn't stop them from charging though.
that semms to be the case with everything not what it youst to be even my wife falls in that group but i hate to hear that about otc
NEW HOLLAND TS6.130 TRACTOR (A51406)
NEW HOLLAND...
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2017 JCB 3CX 15HFCE BACKHOE (A51242)
2017 JCB 3CX...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 WACKER NEUSON LIGHT PLANT (A50854)
2015 WACKER NEUSON...
