Does it have 'float'???
   / Does it have 'float'??? #1
TraderMark
Southeast Georgia
Ford 1720, 2910 John Deere 970, Case 1845
I'm going to add a rear remote valve to my 1720. I really need this option since the tri-deck mower I pull has hydraulic cylnders to lift it for transport.
My question is, does the remote valve that comes in the standard DIA kit have a 'float' position? My mower has three decks and when lowered, they need for the remote valve to be in float position so the decks can follow the contour of the ground.
I can't tell from the parts diagram and I can't find any info on whether or not this valve is pressure up and pressure down only or if it also has the float position.
Do any of you guys with a '20' series, or the newer T1510, T1520, TC30 have the added rear remote?
Thanks!!!!
Mark
   / Does it have 'float'??? #2
If the valve doesn't have a float position (which I expect is the case), can you put a short section of chain between the cylinder and the mower?
   / Does it have 'float'??? #3
Thanks!!!!
Mark
With some valves, float can be added. If not, here is a separate float valve you can add.
Surplus Center - HM-8 FLOAT VALVE
Thanks J_J!
I didn't think of a separate float valve.
I was hoping the OEM valve did have the float position because it would be a neater install, but RickB informed me the OEM valve does NOT have a float position and Ford doesn't offer a kit to add the float position so I think I'll just spend half the money I was going to spend for the OEM valve and get something from Surplus Center or Bailey's that has a built-in float.
Mark
377059 (A51572)
377059 (A51572)
2010 20' Sea Container Mobile Hospital (A50774)
2010 20' Sea...
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
2017 TRANSCRAFT TANDEM AXLE DROP DECK TRAILER (A52576)
2017 TRANSCRAFT...
2016 John Deere 6155M (A50120)
2016 John Deere...
P.T 10' Mower (A50121)
