Does LED lighting work for artificial plant light?
   / Does LED lighting work for artificial plant light? #1
arsenix2001
Central Maryland
Kubota L3540 HTSC-3
You can go as close as physically possible as leds generate practically no heat. Ensure all foliage recieves light. Blue spectrum promotes plant growth and red spectrum enhances flowering stage. Sounds like a nice little setup.
   / Does LED lighting work for artificial plant light? #2
Don't think it matters what kind of lighting you use on an artificial plant
Wtf? I answered a thread that now is gone and i have become the op. Odd.:confused:
   / Does LED lighting work for artificial plant light? #4
Could have been spam as I wouldn't really expect to see something in this section about LED's and plants
   / Does LED lighting work for artificial plant light? #5
There is quite a lot of information about LED grow lights. The Red and Blue combination make a "magenta" color that is supposed to be optimal for growth.
from what I have seen, they are built with a ratio of 3 red led's to 1 blue led. I have found several sources for bulk led's and am considering building one of my own. That way, I can build it in the size and shape best suited for my set up.
When looking at buying led's, remember that there are different degrees of light dispersion. something in the 30 to 45 degree would just about be right. That being the case, being closer to the plant won't help. You need to have it at a distance that the "cone" covers the entire area or it won't be he "magenta" color.
   / Does LED lighting work for artificial plant light? #6
I don't see how any kind of light could make an artificial plant grow?
2019 Allmand Bros Maxi-Lite II 15kW Towable Light Tower (A52377)
2019 Allmand Bros...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2017 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
2015V Chevrolet Equinox SUV (A53424)
2015V Chevrolet...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
