Does mid 90's L-series have seat safety switch?
   / Does mid 90's L-series have seat safety switch? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I've had a couple of non-starts with my L4200GST that I attribute to the shuttle-shift neutral switch. I jiggle the shuttle shift and it starts right up. Now I'm wondering if I'm supposed to have a seat switch too. I do know I can put the tractor into gear and it will drive away without anyone in the seat, and I've started it many times standing beside it.
JayC
   / Does mid 90's L-series have seat safety switch? #3
My 1998 L2900 GST does not have a seat safety switch.
   / Does mid 90's L-series have seat safety switch? #4
My 2000 L3410 does not have a seat pester me switch. ( I hate them!)
jb
   / Does mid 90's L-series have seat safety switch? #5
No! Thank the Lord!
   / Does mid 90's L-series have seat safety switch? #6
I belive they started the seat saftey switches in 2003 or 2004.
Thanks guys! I didn't think there was a switch there, but I throught I'd check. Actually, with the way the thing jiggles around all the time, it's enough of a miracle that my seat doesn't just fall completely off - I'm still not sure what is holding it on. I REALLY need a new seat.
I think my shuttle neutral safety switch is sticking a bit - hey Kenny, do you know if that switch up by the column or down at the tranny?
Thanks - JayC
   / Does mid 90's L-series have seat safety switch? #8
Jay the shuttle switch is on top, under the small plastic cover. The part that ‘usually’ will cause you problems there is the spring that holds the shuttle shift lever in position. If the handle gets loose and not held in the right place, you can bend unknowingly bend the metal tab on the switch… that will cause you starting problems until you replace the spring and reshape the thin metal tab on the switch. KennyV.
2014 Landoll VT-Plus (A52349)
2014 Landoll...
Unused 2025 CFG QNT45 Mini Excavator (A50322)
Unused 2025 CFG...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A50322)
2021 ASV RT-135...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
2016 TROXELL 130BBL VAC TRAILER (A52472)
2016 TROXELL...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
