Does the RK line have a computer
   / Does the RK line have a computer #1
4tillingdirt
nc
N/A
On the larger tractors like the 37 and 55 with the yanmar, do they have an engine computer? Just wondering because the newer T series TYM tractors with the kukje only have a computer that controls the DPF.
   / Does the RK line have a computer #2
I would expect any tractor with a DPF to have a computer controlling the operation. Last year you could stay below 25 hp and avoid them. I don't know what this year has brought.
   / Does the RK line have a computer #3
   / Does the RK line have a computer #4
Those RK tractors use common rail engines, will have a ECU and most likely the emissions are integrated with it.
The Kukje engines are pure mechanical engines and therefore on Branson tractors, you can just unplug the DPF/DOC controller out, gut the canister and have a perfectly good running tractor without all the emissions non sense.
I don't know however if this also applies to TYM tractors fitted with Kukje engine. I don't see why not though.
2000 Kiefer Bilt 20' Gooseneck Trailer (A59814)
2000 Kiefer Bilt...
2012 TROXELL 130 BBL STEEL (A58214)
2012 TROXELL 130...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
