Done did it!
   / Done did it! #1
DirtHauler
Northern Cali ~~~ "Weed" Country
" '06" Kioti CK30 2015 Mahindra 2555 shuttle 2019 Massey 1760M
I finally got the courage to rebuild the lift cylinder on my CK30 with over 3000 hrs. The lift arms had been doing the "slow drop" for a couple years now even when there was no implements attached and adjusting the MLS proved fruitless and hopeing it would cure itself didn't happen. And looking at the repair manual several times, which is scary when you see all the stuff Kioti says you have remove to get at it, so I decided to do it my way which made it alot easier than thier way. Toughest part was breaking loose the top cover because there's no gasket used when assembled. To make a long story short, after pulling cylinder out, upon removing the piston, found the "O" ring had hardened (due to age)and the piston had some pretty good scoreing on it, thankfully the cylinder was OK. The only way that could happen, I'm guessing, is the factory dosen't flush the hydraulic system of "junk" when they assemble the tractors. So I ordered a new piston (took aweek to get) put it all back together with new "O" ring, back up ring, top cover gasket, new fluid & filter. So now, no more dropping lift arms!
P.S. still don't understand why Kioti says to remove the ROPES and fenders etc.
   / Done did it! #3
Did you have to have a spanner wrench to get into that cylinder? I have re-built cylinders on Mercruiser I/O's, but not a tractor one.....yet.
   / Done did it!
No spanner needed, it's just a free floating "piston" in an opened ended (one side) cylinder that pushes on a rod that is connected to the lift arm shaft.
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2005 Nissan Pathfinder SUV (A50324)
2005 Nissan...
1999 Ford RV , VIN # 3FCMF53S2XJA29020 (A51572)
1999 Ford RV , VIN...
2001 Club Car Carryall Utility Cart (A51691)
2001 Club Car...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
(9) 2 PLUG VALVES 1502 IRON (A52472)
(9) 2 PLUG VALVES...
