Dont know how to start
   / Dont know how to start #1
Mike4
Iseki ts1610
Hi I have just got myself a iseki ts1610 and the old owner did not know how to start it ie press this turn that and so on any ideas
   / Dont know how to start #2
Wow! That must be a low-hour tractor!;):laughing:
Seriously, most tractors are started by having the transmission in neutral while sitting in the operator's seat. The seat probably has a safety switch unless it has been bypassed. If you have a fuel shutoff lever, pull it to the operate position and then turn the key on to the glowplug preheat position and then fully to the starting position. That should get things going. I don't know the specifics of your tractor so I'm making a few guesses. Someone with Iseki experience can surely do a better job than me.
   / Dont know how to start #3
Yes, most new equipment is loaded with safety switches. I found myself in the embarrassing position a little while ago of having a tractor delivered by private carrier, and I couldn't figure out to start it to get it off the trailer! Being in the dark during a rainstorm didn't help. Turns out it needs the PTO to be off, the brakes set/pressed, the clutch depressed, both main and aux transmissions in neutral, and the someone's butt in the seat. Pretty annoying...
So when you say you can't get it started, does it crank but not fire, or not crank at all?
   / Dont know how to start #4
Try all that except, Push in the fuel cut off rod, and make sure the high low lever is in neutral?
   / Dont know how to start #5
Just wondering, you bought it without knowing if it even runs?
You may need to check if the battery is still charged, it could be dead, before you do a whole bunch of other things.
We have no idea on how long since it was last started. :)
   / Dont know how to start #6
Pretty annoying...
It's so comforting to know we are being protected from ourselves (as defined by lawyers who are, in reality, preemptively protecting corporations from us).
Are we safe yet?
   / Dont know how to start #7
every time I see a warning lable.. I just know, that somebody, somewhere did the thing they warn agains. like using a push lawnmower as a hedge clipper.. etc...
soundguy
   / Dont know how to start #8
soundguy
I suppose once is enough to add another safety interlock, or federal regulation. How many ways can we race to the bottom (for someone's bottom line)?
   / Dont know how to start #9
I have had a 1610 and an 1810 and don't remember anything to it other than giving it a little throttle, pushing in the clutch and turning the key.....don't recall any other safety switches other than the clutch but it has been years now since owning them so it's possible there's something I'm forgetting.
   / Dont know how to start #10
If the transmission has a high/low shift lever, that lever generally has a neutral position. There could be an interlock switch that requires that shift lever to be in the neutral position in order for the start switch to work and get juice to the starter motor. My 1964 Massey Ferguson 135 diesel is set up that way.
2013 Nissan Sentra (A50324)
2013 Nissan Sentra...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
John Deere 850 Tractor (AS IS) (A50774)
John Deere 850...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
