Don't Let This Happen to YOU!
   / Don't Let This Happen to YOU! #1
boustany
Platinum Member
Campbellville, Ontario
Kubota L3010, BX2200
Don\'t Let This Happen to YOU!
So, we had snow the other day and I figured it was time to hook up my rear blower. Seemed easy enough - I had done it a few times already.
Things went smoothley until I tried to hook up the PTO driveshaft. It wouldn't hook up tractor side! I fought and cursed and fought and crused for over three hours in the cold. The 'snap in' ball bearings were jammed!
So, I spent another half hour removing the shaft, figuring I'd bring it in the house, warm up, and figure out what the problem was.
By then it was getting dark, so I figured I would look at it in the morning. First thing in the morning, I got out cleaning solution and worked on freeing those jammed ball bearings.
Then I made an important observation: apparently, you pull back on the slip ring while sliding the shaft forward! Doh!
Almost a half day wasted in the cold ....
   / Don't Let This Happen to YOU! #2
Re: Don\'t Let This Happen to YOU!
I think you have found out the exact cause of the problem - indirectly. It was cold and snowy. The brain does not work well under those conditions. I've had similar problems and always blame it on the cold weather. /w3tcompact/icons/wink.gif Or hot weather, the rain, the cost of diesel fuel, [place your excuse here]... /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
Terry
   / Don't Let This Happen to YOU! #3
Although I won't admit doing what you did, I just wonder how you got the shaft on the first few times??????
   / Don't Let This Happen to YOU! #4
I've been told that most problems are caused by a direct short between the seat and the steering wheel.
   / Don't Let This Happen to YOU! #5
I've always found in being an auto mechanic it's the nut that holds the wheel causes most problems,maybe it's the same with tractors?
   / Don't Let This Happen to YOU! #6
Yepper that nut that holds the steering wheel is the part that causes almost all auto accidents. A very dangerous ans fallable part it is :)
   / Don't Let This Happen to YOU! #7
The difference between a novice and an expert is the number of mistakes. Learning by doing is usually remembered, something learned by listening is usually forgotten. My experience as a Maint. Supervisor in a factory. I doubt that any TBN'er hasn't made a few mistakes, I know I've made my share. /w3tcompact/icons/blush.gif /w3tcompact/icons/blush.gif Happy tractoring! /w3tcompact/icons/smile.gif
Jim
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
2011 Kubota M7040SUD 68HP 4WD Utility Loader Tractor (A49461)
2011 Kubota...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2018 FREIGHTLINER...
2012 MACK CHU613 (INOPERABLE) (A50854)
2012 MACK CHU613...
2019 BOBCAT T770 SKID STEER (A51242)
2019 BOBCAT T770...
