draining fuel
   / draining fuel #1
Anonymous Poster
Epic Contributor
Hello, does anyone know how to change the fuel filter on my L3000 Kubota, do I have to bleed the air out or will the fuel pump just refill the lines? Thanks/w3tcompact/icons/smile.gif
   / draining fuel #2
Well if its like my l235 you have to bleed the line first after you change the filter. On mine you have to break the fule line nut above the fuel filter and the the nut that goes into the fuel pump on the other end of th same line then close them once the fuel starts comming out.
and you dont have to crank the eng to do it it works off of gravety.
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A51039)
2014 Ford F550 4x4...
2003 John Deere 1790 Planter (A50657)
2003 John Deere...
Deere 9970 Cotton Picker (A51039)
Deere 9970 Cotton...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
