Rotary Cutter driveline shield & bearings
   / driveline shield & bearings #1
thartson
Schulenburg, TX
John Deere 4105
I have a John Deere 4105.
And a Land Pride RCR 1860 5' rotary cutter attached.
Two easy questions for which I am stumped...the owners manual is useless as regards...
(1) is the grease fitting for the driveline shield bearings the plastic nipple at the end of the shield in front up by tractor & back near cutter? I couldnt get the grease fitting to snug over it
(2) how to remove the driveline shield?
I'm a new owner, very savvy with this stuff but a bit lost here.
Thanks - Tyler
   / driveline shield & bearings #2
Thanks - Tyler
The plastic nipple serves as a reminder that there is a zerk in there to grease, rotate the plastic shield to line up the hole in the shield to the grease zerk on the shaft, both front and back ... to remove there are some clips where the larger part meets the smallet part, push them in.
   / driveline shield & bearings #3
Read page #25 of your manual. easyest if drive line is unhooked from tractor, Take the tractor end and swivel it around to find zerk and with end to one side it is easy to grease it in this position. Same with the other end, but would be easyer if driveline was unhooked from gearbox. hope this helps
Firetruck non runner (A50323)
Firetruck non...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2008 Ford F-250 Ext. Cab Pickup Truck (A50323)
2008 Ford F-250...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
