Help !
Purchased a new 296 Bush Hog cutter and I can not get getthe drive shaft to attach to the PTO tractor shaft. My manuel simply says to push the drive shaft onto the PTO shaft until it "clicks" (my words) and make sure it is secure and won't pull off. There is a ring on mine that I suppose I am to pull back while I slide the connection on to the PTO shaft. That ring is hard to pull on anyway, but I never got the drive shaft on.
I tried to inspect the attachment threw all the grease and see if while I held the ring back I could press the "snap bar in that takes the place of a bolt on other drive shafts. That "bar" would not press in.
Any ides or was my explanation clear as mud ?
