nikdfish
Veteran Member
It didn't go exactly as planned but ended ok. We had some concerns about how safe it was working around it since it appeared partially hollow at the base & was missing big sections of bark along the length. The main trunk was 50' + in length and there was another 20' or so of sub divided trunk & vertical limbs. The base at ground level was about 24" & about 20" at the point I cut.
Since I was not sure about the internal integrity of the trunk I wrapped a length of tie down chain around it about a foot above the cut point. It stayed together but did not fall quite as intended. It ended leaning on another tree. I used the 1025R nudge it over a bit to give me a straight pull line, then attached some chain & pulled the butt end back until it disengaged & fell the rest of the way. Even with the backhoe mounted, in 4WD with the differential locked, the wheels were spinning. Luckily I wasn't too far from the paved subdivision roadway so a couple of chain lengths put me on asphault. That made all the difference & it moved pretty easily at that point.
It gave the new Stihl a work out cutting it into manageable lengths. Dry red oak is some tough stuff & most of the internal structure was very solid. About as much as the wife & I could handle as an afternoon's work. Getting a bit long in the tooth for big stuff.
So anyway, one down & a bunch more to go in our woods cleanup...
Nick
Nick
