DT360 Filters
   / DT360 Filters #1
tj1989
Does anyone know the crossover filter numbers for the DT360? I need a new air filter, hydraulic filter, oil filter but do not know what Wix or other filters I can use in replace of the factory filters. Thanks for everyones' help.
   / DT360 Filters #2
Check out this thread and find your Montana equal on the PDF in the first post. http://www.tractorbynet.com/forums/montana/86217-magic-filter-xref-list.html
Is your DT360 the same as a Montana 3840?
If it is here are some donaldson part numbers that should work
Fuel P502134
Air P821575
Oil P502067
Hyd P55242
   / DT360 Filters #4
So if it is the 360DTC I presume it is the same engine as my 390HST.
Farmtrac / Landtrac PN: Q1400001
WIX PN: 51064
NAPA PN: FIL 1064
Using that you can go to any auto store and pick one up. I ended up buying a little bit higher quality one from Advance and getting a wrench to fit it. The original Farmtrac filter will have a PN on it, and if it is the same as above those #s should work. I think I crossed them off the Wix site.
   / DT360 Filters #5
Here are the filters from the parts manual on the 390 HST:
Hydraulic / Hydro: LG4399 / A1823315
Oil: LG2659 / MD134953
Air primary: LG3304 / A1190111
Air Safe: LG3305 / A1190112
Interestingly the oil filter MD134953 references a different filter than was on the tractor. The specs on WIX's site indicate a different bypass filter valve setting (that setting is lower on the MD134953 filter) and a slightly smaller housing, but same thread size. I am thinking of trying the different filter next time I change the oil.
   / DT360 Filters #6
Btw, I wnated to ask did you manage to cross reference the air filters to Fram or another manufacture? I wnated to replace the air filters here soon and can't get the ones in the parts manual to cross reference to anything. I did manage to find a fram filter part number for a Mitsubishi S4L engine which I think is the correct primary filter. That part number is CA9550SY. However, I haven't been able to find anything for the outer "safe" filter yet.
   / DT360 Filters #7
Hmm, actually I had a reference to a Montana tractor that had the same engine as the HST390 and I think I found the correct air filters. I crossed PNs:
DONALDSON P822858 to WIX PN 42985 for the inner filter
and
DONALDSON P821575 to WIX PN 46438 for the outer filter.
When I crossed that Fram filter I found, it also crosses to the Wix PN 42985, so I think those are the correct filters. I'll let you know when I get them sometime in the next week or so.
   / DT360 Filters #8
I don't remember all the part numbers but we were able to get all the filters from NAPA.
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2020 INTERNATIONAL LT625 DAY CAB (A51222)
2020 INTERNATIONAL...
Agway Bale Accumulator (A50515)
Agway Bale...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A51242)
2016 JOHN DEERE...
