Du-al front-end loader
   / Du-al front-end loader #1
Busdrver
Memphis, TN
Ford 1710
New poster here. Hoping somebody can provide me with info re a Du-al (or Dual) Manufacturing front-end loader. The controller has developed a leak and I can't find the company. I've searched here and have also Google'd it but no luck.
Anybody know if it's changed names or gone out of business?
TIA.
John
   / Du-al front-end loader #2
Busdrver,
I don't know anything about the loader but I think this is it. "Woods Du Al is located in Sioux Falls South Dakota" I found this on Yesterdays Tractor forum. Do a Google search on DuAll Loader ...
Good Luck,
Leo
   / Du-al front-end loader #3
Also do a Google search on Woods Du Al Loader ... that gets some dealers .... they may be able to help.
Leo
   / Du-al front-end loader #4
Woods bought Du-Al years ago. As the others have said, I'd contact Woods directly about parts. Woods dealers will probably not have the parts manuals for Du-Al equipment. I contacted a couple of Woods dealers recently on a Woods attachment and none of them had the parts manual.
Good luck. Du-Al made good stuff.
   / Du-al front-end loader #5
John,
I've got a Du-al 107 commercial loader. The parts and assembly diagram is for models 95, 105, and 107. My notes on the diagram show that a seal kit in 1993 was $10 to $15. Phone # for parts was 605 336 3860 back then and a Google reverse phone search shows that it is now a Woods number and also some gutter service number. I could mail you a copy of the diagram if it helps.
John
Yes, the diagram would be helpful. Can I send you a SASE?
Also, thanks for the other responses.
   / Du-al front-end loader #7
Post your address here, or send me a private message on this forum, or send a SASE.
I'll send it tomorrow. Thanks.
   / Du-al front-end loader #9
Hey Busdrver If I cxan help in any way give me a holler, Im not too awfuly far from Memphis Im over in Iuka MS. Your valve probably has an oring shot in it thats a commom thing in most spool valves and also an easy fix.
I may do that. I get over that way every once in a while, anyway. I'm going to see if I can find the right sized O-rings here in Memphis tomorrow. If I can't I'll be in touch.
Much obliged. /forums/images/graemlins/smile.gif
John
OK, found some o-rings for the spool valves (learned some new terminology), got em replaced and it seems to be holding.
Thanks all for the help and info. Hope I can repay the forum by making some contributions here in the future.
John
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2019 CATERPILLAR 304ECR EXCAVATOR (A60429)
2019 CATERPILLAR...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
2020 INTERNATIONAL MV607 26 FT BOX TRUCK (A59905)
2020 INTERNATIONAL...
