Dug a 40' x 4' x 18" deep trench today...
   / Dug a 40' x 4' x 18" deep trench today... #1
Mowbizz
Platinum Member
Lakes Region, NH
'14 Kubota BX25D
BX24 here...got a job where a guy wanted to plant a wall of arborvitae to use as a fence between him and a not so neat neighbor's backyard. He wanted a planting trench for his mature shrubs (12 arborvitaes 12' tall each). Had access to the trench from one side only (property line) and didn't know quite how to approach starting the job....I ended up starting in the middle and got one half done with just the FEL...trouble was the guy didn't want to have any "spoils" near the trench so I had to take each bucket load to his back woods (80' away) and through lots of trees...
Now my dilemma as I found out was finishing the trench with the FEL was impossible as it turns out...my entry ramp into the trench would have disappeared if I backed into the finished side and started to use the FEL to go in the other direction...would have ended up with no ramp and in a 18" trench.
Had I started from the one end of the trench which had access down into it I would have been ok...ended up finishing up the latter part of the trench with the Backhoe. Came out ok and he was happy he didn't have to shovel the trench himself...This was a scenario which was perfect for a BX sized machine as there was limited access into his back yard and well manicured lawn all around the house...a larger machine just would not have fit. I am amazed by the work this little tractor can do...I really "tested" the FEL as there were many large rocks imbedded in the soil...had to back off many times and take a different bite to get the trench dug...I was pretty proud of the one side I finished with the FEL...was nice and square, level, a perfect 4' wide (plus a couple of inches on each side for tire width) and 18 inches deep exactly...the backhoe side came out a little less neat because of the access from the side only, but ended up plenty deep and wide enough for his needs...this was a big hole for a 12" bucket :rolleyes: I wish I had brought my camera so I could show it off...OH yeah... took 6 hours with no breaks (except one p-break in the woods...By the way, I was quite thankful for having my BroTek skid plates underneath, as the woods had many "hazards" which could have spelled disaster for an unprotected belly...
   / Dug a 40' x 4' x 18" deep trench today... #2
My BX23 will pick itself up out of an 18" hole. Lift the front end with the FEL on the edge of the hole (bucket flat on the ground). Drive forward till front wheels are on solid ground. Lift rear end with backhoe, and push tractor forward with backhoe.
ron
ron
Hmmm never even thought of using the FEL and Backhoe to "get out" lol...good thinking and something I'll have to remember for the future...:rolleyes:
(still a tractor noob here)
   / Dug a 40' x 4' x 18" deep trench today... #4
By the way, that's how you get the tractor off of a narrow trench. Set the FEL bucket flat on the ground. Left the rear end with the backhoe and swing it off to the side away from the spoils. You may need to do this twice. Back up until front wheels get on firm ground. Raise FEL, and away you go. You should have seen me before I learned that trick!
ron
2017 FORD F-550 XL SERVICE TRUCK (A51406)
2017 FORD F-550 XL...
2023 John Deere 408R Sprayer (A53342)
2023 John Deere...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
Gravely 3000 RTV (A51573)
Gravely 3000 RTV...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
