psdx
This is probably a dumb question, but I've never run across this before - guessing someone on here already has...
I'm greasing all the moving parts on my Kubota mower and one of the zerk fittings doesn't want to accept grease. So I replace the zerk nipple thinking it must have been due to a plugged up fitting. Unfortunately the new grease fitting does not fix the problem and it still doesn't want to accept grease.
When using a pneumatic grease gun - it just stalls and does nothing. When using a manual grease gun, I can operate it with difficulty, but after 100 or so pumps there's nothing coming out anywhere so it appears that the grease is not flowing in.
It shouldn't be this hard but I've never run across this before. As a hint, the dealer would have had this joint apart during a service visit - if that matters at all. The only possible thing I can think to do is shorten the threaded portion of the fitting, thinking possibly it's too close to the bushing inside.
Any thoughts, ideas or suggestion would be appreciated. Thanks!
