Mar 20, 2013 / Dump truck hydraulic oil ? #1 H Heavyduty Gold Member Joined Nov 2, 2008 Messages 337 I have an older Ford truck with a dump bed. The hydraulic oil for the dump bed is dirty, so I need to change it, what type of hydraulic oil should I use?
Mar 20, 2013 / Dump truck hydraulic oil ? #2 R rustyshakelford Veteran Member Joined Dec 7, 2012 Messages 1,769 Location Texas Tractor Deere 5100E/H260/MX15 I'd just use the cheap stuff from tractor supply. $35-37 for 5 gallons brett
Mar 20, 2013 / Dump truck hydraulic oil ? Thread Starter #3 OP H Heavyduty Gold Member Joined Nov 2, 2008 Messages 337 Thanks brett, I'll see what I can find at TS.
Mar 21, 2013 / Dump truck hydraulic oil ? #4 Xfaxman Super Star Member Joined Feb 8, 2013 Messages 12,896 Location Guthrie, OK Tractor Toolcat 5610 G - Bobcat V417 - TORO+Loader It may use motor oil, check the viscosity, quick thin drip = hydraulic oil, slow thick drip = motor oil. I would use motor oil in an old system. :2cents:
Mar 21, 2013 / Dump truck hydraulic oil ? #5 Soundguy Old Timer Joined Mar 11, 2002 Messages 51,575 Location Central florida Tractor RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC very likely any ro/iso 32/46 will work.. but many times tsc carries some UTF fluid in the same $$ rnage.. and utf is better than plain hyd oil.. etc.
