Dust seals on RC100
   / Dust seals on RC100 #1
QwikDraw
Platinum Member
North East
Timber King TK711
What is the best way to remove the bearing seals on the idle wheels and rollers on an ASV? I had the front idler bearings go and when I removed the track all the rollers and rear idler bearing have play in them. I bought the whole assembly (axle/hub) and replaced it. I also purchased a set of bearing for one roller to see how it was to change them and I had problems removing the dust seal. I finally used a BIGGER hammer and just beat the axle through but I know that's not right since you have to break the clip that holds the bearings in for this to work...
So what's the right way?
   / Dust seals on RC100 #2
Just call ASV. I just call them whenever I have a question on my RC50. They are still one of the few companies that you can call direct and they've always been great to deal with. 1-800-346-5954 is the number. Just ask for the service department. You can also get this information right off of their website under the "Contact Us" section. Good luck.
   / Dust seals on RC100 #3
I just did the seals on my 287B (same undercarriage) the bearings were fine, the seals were leaking. I removed the whole assembly , removed the 2 outside wheels, clamped it in a vise, and drove a huge screwdriver into very outside edge of the face of the seal and started prying, then did the same 1/2 way around, then used two screwdrivers at the same time to pry across from one another. It takes forever and be ready to snap a few screwdrivers (Craftsmans the way to go) the seals are about an inch thick and are stubborn as ****. I'm sure they some kind of special slide hammer tool that srrews into the seal to remove it, but since my bearings were all good I didn't want any shrapnel to get into em.
My seals were leaking too. The whole assembly was full of mud on the one hub that I did change, I was surprised because the seal didn't look bad from the outside. I wish each roller/idler had a grease fitting..I don't understand why they don't since the seals are not great and will eventually let in dirt/mud.
2018 GMC Acadia AWD SUV (A48082)
2018 GMC Acadia...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
UNUSED White Metal Roof Panels (A50860)
UNUSED White Metal...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
Axle (A50860)
Axle (A50860)
