Early BX2200 and LED Lights
   / Early BX2200 and LED Lights #1
rs191
Adirondacks, NY
BX2200, bought June 2000
I have seen many threads about BX2200 lighting improvements, but haven't seen a solid answer about auxiliary LED lights. I bought my BX2200 in 2000, so later models probably have different power supplies?
I tried LED bulbs in the "headlight" sockets and they flickered constantly, they were unusable. If that flickering was because of the power supply, is there any hope in trying the Harbor Freight Roadshock add-on LED lights?
   / Early BX2200 and LED Lights #2
Good question... I was thinking the same thing as I got a BX2200...
   / Early BX2200 and LED Lights #3
If you have the dynamo for charging there is a possibility that they are feeding half wave DC or maybe even AC to the lights and the other half of the wave is going for battery charge. May need to upgrade to the 40amp alternator.
David
   / Early BX2200 and LED Lights #4
^ Forgot about that. Yes, I just got the dynamo.
I am thinking of getting the alternator, but I plan on upgrading the machine... so, eh.. lol
   / Early BX2200 and LED Lights #5
As an FYI, the BX's dynamo charging system produces 12-14vDC @ upto 14 amps. The dynamo is a very simple alternator that utilizes permanent magnets and it uses an external voltage regulator/rectifier to supply DC voltage to recharge the battery and run the tractor's electrics.
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE DAY CAB (A45677)
2020 FREIGHTLINER...
Rolyan Regulatory Buoys and Carmanah M550 Solar Marine Lanterns (A45336)
Rolyan Regulatory...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A45336)
12-Wheel Pneumatic...
Polaris Ranger (A46684)
Polaris Ranger...
PT 8'x18' 4 Wheel Wagon (A47307)
PT 8'x18' 4 Wheel...
Kubota TE4052T Hay Tedder (A47307)
Kubota TE4052T Hay...
