two4spooky
Bronze Member
I have learned so much from this site I wanted to share, maybe help in some small way. The issue I had seems to be fairly common; water mixed with the gear box oil. The difficulty is the gear boxes do not have a drian plug, mine only has the breather/dip stick and check level plug. To drain the gear box I needed to either a) lift the cutter on it's side to have the check level plug down (not ideal as the mower weights 1100 lbs) or b) suck the oil out (90wt is bit thick). My helper and I decided "b" sounded a bit safer. I do not have a pump(added to the want list) that would work but I did have some tubing and a rubber sqeeze bulb for adding water to batteries. I learned it takes a LONG time using the bulb to suck 90wt. from a gear box. Even with the cutter deck blocked up on the off side and the oil thinned with water the milky fluid is too thick. Did I mention it takes a long, long time with the bulb? The effort saver was to use the tubing to siphon the oil to a container at a lower lever. Get it started flowing then go fix a cup of coffee while gravity does the rest. :thumbsup: So after draining and refilling the gear box oil four times I learned: 1) start with deisel fuel(THANKS Soundguy!) to wash out the box, 2) use motor oil next -thinner than gear oil and I had a bit on the shelf, 3) if you do not have a small drill pump use gravity to siphon the oil out. Anywho...TBN'ers probably already knew all this but for me it was new. A couple of pics of my mess and my helper
