Echo and Cub Cadet same trimmer??
   / Echo and Cub Cadet same trimmer?? #1
milkman
Elite Member
Ky. Between Dead Horse Holler and Yellowbank
BX2200, BCS 735
I'm looking at new string trimmer, Echo at HD is $199 last time I looked. Cub Cadet at TSC looks like Echo, different color, is $199, Cub at Lowes is about $30 cheaper than TSC. Is the engine on the CC from Echo, or a copy. The trimmer I really want is the Husqvarna, but can't get the shaft that I want. Lookin for some wisdom.
   / Echo and Cub Cadet same trimmer?? #2
</font><font color="blue" class="small">( I'm looking at new string trimmer, Echo at HD is $199 last time I looked. Cub Cadet at TSC looks like Echo, different color, is $199, Cub at Lowes is about $30 cheaper than TSC. Is the engine on the CC from Echo, or a copy. The trimmer I really want is the Husqvarna, but can't get the shaft that I want. Lookin for some wisdom. )</font>
milkman,
I doubt they are the same trimmer. If you go to <font color="teal">Cub Cadet Commercial</font> you'll see that
they're using the Shibaura engine. The ECHO engine is made by Kioritz.
It's a shame people can't seem to get over the Stihl/Husqvarna idea being the ultimate. The best stuff don't always have to come from Europe. /forums/images/graemlins/crazy.gif ECHO products are top shelf. You will like the grips better on the ECHO than the Husqvarna.
   / Echo and Cub Cadet same trimmer?? #3
I have husky & maruyama. Both excellent trimmers They both have solid steel shafts . when I was in the market echo only made 1 trimmer with a steel shaft. I've had too many flex cables to break.
   / Echo and Cub Cadet same trimmer?? #4
I know about the cable driveshafts. They are lifetime warranty items, though. Personally, I don't like them. The commercial (read - expensive) ones are steel drive shafts.
There is still a brand that has all their models steel drive shafts - Shindiawa. They just don't have too many dealers though.
   / Echo and Cub Cadet same trimmer?? #5
I believe that Echo's flex shafts are a patented design, and they do have a lifetime warranty. I wanted a solid shaft but ended up buying a flex shaft, because there is less shock on the engine when using the blade than the solid shaft.
Any way My echo stuff is great. I have used Stihl and they do work well too.
I like the Echo trimmer also, but to get the straight shaft with the disconnect to use other attachments, I would have to go to the high dollar pro models. I can't justify the $$$ for that since the non pro models would do more than I can do with them since I only have one good (make that better than the other) shoulder to operate it with.
   / Echo and Cub Cadet same trimmer?? #7
I have an Echo and Shindaiwa gas trimmer. Paid about $250 for each.
I would buy the Shindaiwa over the Echo anyday...
I've heard good things about the Shindaiwa also, just missed a good sale on those when a hardware went out of business in town about 20 miles from here.
   / Echo and Cub Cadet same trimmer?? #9
I now have two trimmers, a new $199 Echo from HD and an FS55 RC Stihl. Both trimmers were $199 and are residential/light commercial usage. I use them to cut my lawn as well as my parents property. Next year I hope to maybe take on a few more jobs. I have 2 trimmers because I had problems with the Stihl running. But seems the dealer fixed that issue. The ECHO is a great trimmer. Its light, quieter and the bump feed works with less "bump". I think both are good machines, but they feel differently in hand. If I had to choose one over the other,...... I'd have to go with the Echo.
Gonna have to get back by HD and check out the Echo again, but I really want on with the disconnect to run other attachments, may have to check out an Echo dealer next time I go the town.
2021 Dodge 5500 SWR ST CC Crew Cab 4x4 Mechanic Truck (A45336)
2021 Dodge 5500...
(3) Front Tractor Weights (A46502)
(3) Front Tractor...
2017 Chevrolet Silverado 2500 (A45336)
2017 Chevrolet...
2002 Genie S125 125' Manlift (A45336)
2002 Genie S125...
Corner & Edge Hedge Post (A46502)
Corner & Edge...
John Deere TX 4x2 Gator (A47307)
John Deere TX 4x2...
