EGR valve on L2501?
   / EGR valve on L2501? #1
gwstang
Platinum Member
Lake Martin Alabama
1952 Ford 8N / Kubota L2501
I looked through the manual but can't quite figure out if the L2501 new model I have, is an external or internal or none at all EGR valve? Seems to be a difference in the type of oil to use based on the configuration.
   / EGR valve on L2501? #2
Gary,as for engine oil selection,it will not matter if you have EGR or not.
Current diesel oil specs are CJ-4.
Kubota ships with 10W30 conventional oil as the factory fill.
You may elect to use 15W40 in your warmer climate as almost all are CJ-4 rated.
10W30 diesel is still fine,as as far as current motor oils go(thin is in!)
There are also many synthetic 5W40 diesel oils out there should you prefer.
Also,I forgot to mention,Kubota is woefully out of date on oil specs in their manuals.
Good Luck!
Nice Tractor.
Thank you so much for the info!
1996 Chevrolet IMPALA SS (A51222)
1996 Chevrolet...
7046 (A50322)
7046 (A50322)
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2002 International 4400 SBA 4x2 Flatbed Truck (A50323)
2002 International...
