ELECTRIC BLANKETS ?
   / ELECTRIC BLANKETS ? #1
bullbreaker
Elite Member
SW FLA
D Ranchers daughter'$
I have been put in charge of purchasing ( for Church) if research I do is "positive" in regards to safety,etc some electric blankets. Being down here in SW Fla I don't know much about them. The idea is they would be for some adults and children that live in poorly insulated or heated houses,trailers,etc . One particular young man that comes to mind was born with no arms. Of course when in use if research proves positive the people that require extreme special care are never left alone.
Please could anybody here on TBN site give me thoughts on brands,safety,negative experiences,etc. The funding for the blankets has already been provided,cost is of no concern . Thanks in advance !
Boone
   / ELECTRIC BLANKETS ? #2
I have never used a heated mattress pad, so I can't comment on them. We have had a Sunbeam electric blanket for over 20 years. It has a removable cover on it, when it comes time for cleaning. It has Lo-Medium-High temperature settings. One thing that we have enjoyed about it is the convenience. My wife gets colder than I do, and she can use it on her side of the bed only, or if I need some additional warmth, I just pull it back over my body parts that I choose. I do not think that a heated mattress pad would provide this convenience function. You can take an electric blanket with you from room to room if the temperature change varies, in case one family member thinks the thermostat is set too low-cold, and the other one needs additional warmth. Electric blankets come in different sizes. If this ends up being your choice, I would most definitely buy those that are UL tested. Just my thoughts. BTW I respect you for your and your Church's efforts in reaching out and helping the less fortunate members in your community.:):thumbsup:
   / ELECTRIC BLANKETS ? #3
My thoughts are along this line. A quality blanket never breaks, it will last down to the term ( thread bare ). And you do not have to worry if an infirm person uses it. To clean it, probably just simple soap and water. And in case of a power outage you just put on more blankets.
Craig Clayton
   / ELECTRIC BLANKETS ? #4
I had a follow up thought , I was talking about WOOL blankets, meaning they never break.
Craig Clayton
   / ELECTRIC BLANKETS ? #5
Yes -mattress heaters come in twin - king sizes, multi control, & multiple heat settings. You're not thinking of the old hot brick in a pan bed warmers are you??? :confused: MikeD74t
In response to your post: My statements verbatim were "I have never used a heated mattress pad, so I can't comment on them" and "I do not think that a heated mattress pad would provide this convenience function". I was referring to the convenience of only one person in the bed using the blanket or both. I was also referring to the ease of taking an electric blanket to another area in the home. My Wife had a heated mattress pad during her stay in the hospital, and I am aware of their capabilities such as dual heating areas;etc. Not once did my post show any indication that I suggested that heated mattress pads did not come in different sizes and were not equipped with multiple control and heat settings. Mattress pads are normally slept on top of, and a person usually sleeps under an electric blanket.It was my intention to assist bullbreaker in his righteous undertaking. I do not understand why you posted "You're not thinking of the old hot brick in a pan bedwarmers are you???:confused: Most everyone that posts on a thread is trying to assist the OP in regards to his questions and inquires.That was my sole purpose. I wish bullbreaker the best in his endeavor, and hopefully some deserving and unfortunate individuals will benefit by his Church's program.
   / ELECTRIC BLANKETS ? #6
If they can't afford turning the heat up, how can they afford powering the electric blankets ?
Another vote for the wool blankets.
   / ELECTRIC BLANKETS ? #8
Electric blankets pull a small fraction of the power pulled by an electric heater. I cannot remember exactly, but under 200 watts comes to mind. You are heating a smaller area. Electric heaters are around 1500 watts.
   / ELECTRIC BLANKETS ? #9
I've used both, the mattress pads and the blankets. Although the mattress pads seem like a better idea, I think the blankets are more comfortable.
To address your question directly, there are low voltage blankets which might be the answer. It's just a transformer and wiring designed for 12v. The original reason for the design was to eliminate EM radiation thought to be more dangerous because of the minimal distance between the body and the source. I don't think that's the concern it was, but the risk of electrocution to someone with limited mobility is reduced.
   / ELECTRIC BLANKETS ? #10
We've had the electric blankets and the mattress pad, if it is not moved around alot, the pad is far superior. My wife sleeps with her side on high with a thick down duvet, I leave mine off and use a thin flannel sheet. Keeps us in the same bed. We do also have a small heating pad that bounces around the house to different places. Its only 35 watts or something but lets someone be comfortable in a cold room.
Land Honor Portable Screener (A50514)
Land Honor...
2021 FREIGHTLINER 126 SLEEPER TRUCK (A51222)
2021 FREIGHTLINER...
SAKAI SV510 SMOOTH DRUM ROLLER (A51242)
SAKAI SV510 SMOOTH...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
John Deere 350 PTO Manure Spreader (A52128)
John Deere 350 PTO...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
