electric brake controllers?
/ electric brake controllers? #61
Followed this thread... I looked tonite; my Prodigy is the P2. It replaced a Tekonsha Sentinal.
It works much nicer. But, I don't tow very much; my 27' 5th wheel(no slides or anything) is only rated 7500lb max.
/ electric brake controllers? #62
/ electric brake controllers? #63
Actually, electricity does not flow at the speed of light. It's MUCH slower. It's more on the order of 8-9 centimeters PER HOUR.
Wire lengths DO matter, but only if you're working with differences in length that are significant. Over a 30' run of wire, a few feet of difference is not even measurable. As long as all of the wiring is the same gauge, and the lengths are all within 10-15% of each other, there is zero measurable difference in how quickly a brake will react.
True, but my point was that the length of wire (within a reasonable difference of 2-15 feet as could be seen in a trailer brake connection) will not make any appreciable difference of how fast the trailer brakes are applied (assuming that the wires are sized properly).
Aaron Z
As was mine in the post I quoted.
2 Door Refrigerator (A60352)
2 Door...
2012 SOUTHERN VAC 130 BBL STEEL VACUUM TRAILER (A60736)
2012 SOUTHERN VAC...
2011 MACK CHU (PINNACLE) (A60736)
2011 MACK CHU...
2020 Hino 195 20ft. Electric Box Truck (A59230)
2020 Hino 195...
2015 CHEVROLET SILVERADO 2500HD (A60736)
2015 CHEVROLET...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
