</font><font color="blue" class="small">( I put up 3 runs of a product like electobraid rope on a straight run about 700 ft. long. I purchased a solar powered charger that's good for 3 miles. I placed a rod in the ground for my ground, ran a wire to the ground screw on the charger. I placed a connection on the top strand of rope making sure it was in contact with some of the wires and attached it to the charger. Here's my problem. Ropes 2 & 3 are not even hooked up at this time. Sometimes I can grab the top rope and not feel anthing, sometimes I can barely feel a pulse but not enough to make me let go. But if you touch another part of your body on strand 2 or 3...You will get a shock off the top strand to make you let go. What did I do wrong. I should be able to grab just the top strand and get a wallop. Any ideas??? Thanks for your help. /forums/images/graemlins/confused.gif )</font>
1. Do _not_ believe those milage ratings on the fencer boxes. That is _just_ like the hp ratings on air compressors these days - a make believe number which is not real. Any fencer rated less than 5 miles is not worth bringing home, in my opinion. You got a real weak shocker.... It is basically telling you it bcomes worthless at 3 miles, and you have 2100 feet of wire - electro braid is thin filiment so it does not carry juice as well as #12 steel wire - all in all, you are over 1/2 way to having a worthless fencer. It will test pretty weak under the best conditions.
2. You need a real good ground. Did you drive the rod 6-8' deep? Really should have 2-3 rods that deep, and in dry conditions they should be watered so there is good contact. So many fencing problems come back to a poor ground. People don't believe it, but the ground rod is as important as the wire, gotta be good. Deep, damp, tight.
3. In dry conditions your livestock will be insulated just like you; hooves & hair are good insulators. A good setup with multiple wires like you have is to make every other wire 'hot' and the others (or a middle one) tied into the ground. As the animal touches 2 wires, it will get a jolt even if it is standing on glass. Much less worry about the ground rod this way.
4. I believe you have created situation #3 with your setup, wich isn't bad. I'd run 2 hot wires and only 1 ground wire, but good job - even if it wasn't intended. /forums/images/graemlins/smile.gif
--->Paul
