electrical fault on acs FC 32 55
   / electrical fault on acs FC 32 55 #1
Oldandrusty
kansas
international
Hmm.. stands on bobcat s175 fault code: 32-55 short to battery (lift handle or pedal) checked around and cant find nothing wrong with it.
anybody had similar faults? :confused:
It reads 5v input on handle and pedal, output is around 2.7v, and moving up/down when moving (only a bit, cause locks are on) with resistance mesurement the wires from handle/pedal to acs are fine.
   / electrical fault on acs FC 32 55 #3
Code: 32-55: ACS Lift Handle / Pedal Short To Battery, SJCRight Joystick Y-axis Short To Battery
Description:
A Code 32-55 occurs when ACS Controller detects a voltage higher than 4.85 volts on the signal wire from the Lift Pedal in Foot Mode, Lift Handle in Hand Mode, or the Right Joystick Y-axis in ISO Mode. The ACS handle and pedal sensors or Right Joystick are supplied 5.0 volts from the ACS Controller. If a Code 32-55 occurs, the lift and tilt functions will be disabled. If the Loader is equipped with analog joysticks and the operating mode is switched to H-Pattern, the code will change to a Code 32-71 "Right Joystick Y-axis OORH".
Possible Cause:
Signal wires 4650 or 4660 shorted to battery.
Supply wires 1510 or 1520 shorted to battery.
Ground wires 2660, 2650 or 2070 open.
ACS 5.0 volt supply.
Handle / Pedal sensor or Right Joystick.
Moisture, corrosion, or pushed back pins in the ACS Controller, Lift Handle, Lift Pedal, or Right Joystick connectors. See Electrical Systems Connector Maintenance in Technical Information.
If the code is intermittent and not on at the time of testing, the cause of the code may not be found at this time. Probable causes may include: loose connections, corrosion, pushed back pins, the controller, the wire harness or a combination of these problems. Refer to Troubleshooting Intermittent Electrical Faults Procedures in Technical Information.
Conditions for Code:
Key switch / (run/enter) On.
Press To Operate Loader (PTOL) enabled.
Conditions for Clearing Code:
Cycle power.Live Data Yes No
1 Is Code 32-65 “Sensor Supply Out Of Range” also displayed?
Troubleshoot Code 32-65 Go to Step 2.
2 Is the Loader an AWS/SJC machine?
Go to Step 7. Go to Step 3.
3 Verify if the Loader is in Hand or Foot Mode. If you switch the operating mode, does the code clear?
Go to Step 4. Troubleshoot a 5 volt supply problem.
4 Check ground wire on the Lift Handle or Pedal for continuity to ground, pedal wire 2660 or handle wire 2650. Is there continuity to ground?
Go to Step 5. Repair or replace wire harness.
5 Go to the Diagnose/Calibrate screen in the Service Analyzer. Move the Lift Handle or Pedal while monitoring the signal voltage. Does the signal voltage go above 4.85 volts?
Go to Step 6. No problem found. Perform a wiggle test.
6 Check for a short to battery on the signal and supply wire to the Lift Handle or Pedal, handle wires 1510 and 4650 or pedal wires 1520 and 4660. Do the wires check out OK?
Replace Lift Handle/Pedal sensor. Repair or replace wire harness.
7 Check ground wire 2070 for continuity to ground. Is there continuity to ground?
Go to Step 8. Repair or replace wire harness.
8 Go to the Diagnose/Calibrate screen in the Service Analyzer. Move the Right Joystick forward and backward while monitoring the Y-axis. Does the signal voltage go above 4.85 volts?
Go to Step 9. No problem found. Perform a wiggle test.
9 Perform a wiggle test while checking wires 4650 and 1510 for a short to battery. Do the wires test OK?
Replace Right Joystick. Repair or replace wire harness
thanks Jabonee!
checked the:
Signal wires 4650, 4660
Supply wires 1510, 1520
Ground wires 2660, 2650, Moisture, corrosion, or pushed back pins in the ACS Controller -all ok.
no Code 32-65, only the 32-55
i cant find the 2070 ground wire? there are 20.. wires at the relays from 2000 to 2060 but no 2070?
can you spot it some where?
   / electrical fault on acs FC 32 55 #5
thanks Jabonee!
checked the:
Can you post the units sn# so I can look at the correct wiring diagram? Is this a SJC or hand foot machine?
   / electrical fault on acs FC 32 55 #6
If you have foot controls your machine is not SJC. I believe the wire 2070 is a misprint. Should be 2270 and is checked at the ACS controller. Its plug J3 (grey) pin H. Pull the plug and check continuity to ground. I'm thinking you may have a bad ACS controller. You will need your dealer to plug in and check voltages.
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
GORMAN RUPP 4 TRANSFER PUMP (A50854)
GORMAN RUPP 4...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
Swamp Buggy (A49346)
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A50458)
CATERPILLAR D8T...
