Exodus
- Joined
- Dec 18, 2015
- Messages
- 3
- Location
- Donegal, Ireland
- Tractor
- Ford 5030, 3610, Massey Ferguson 135, David Brown 770
First time posting so forgive me if this is in the wrong section. Been reading the forms a long time but only just made a account. I have a Ford 5030 and it's head light high beams have been giving bother lately. On bumpy ground the high beams can just cut out similar to a loose wire, so I switch to the low beams which work perfectly. This is annoying until recently when the high beams stopped working together, lows fine. I got out the multimeter removed the bulbs and tested the bulb sockets. I'm getting 12 volts on the low beams and 12V on the high beams also strangely. I stuck in a bulb and dips work grand click the handle over to high beams and nothing, no voltage detected either it just disappeared. H4 bulbs FYI.
What I think is happening is 12 volts but no amps in the high beams wiring due to a fault/short in the wiring. I checked the fuses and relays and everything seems fine. I turned the multimeter over to measure resistance. Switched everything off and hooked it up to the high beams and starts picking up very high resistance. From what I can see it looks like the high beams positive wire is being grounded somewhere causing little or no amps to reach the bulbs but not affecting the low beams. Battery also so slowly loosing it's charge as if a light is always on I'm think it's this.
I anyone could steer me on the right path or give me some advice on what to do it would greatly appreciated. Thanks - Michael
