Electrical problems on Kubota M4900
   / Electrical problems on Kubota M4900 #1
docmx
I've replaced the battery two times in the last year. Found I had a bad alternator and replaced it at the time of the second battery. Now I find the battery is low again!!!??? Voltage reads at 11.98. Any ideas where I might be having a electrical bleed?
   / Electrical problems on Kubota M4900 #2
Does this model use an external regulator?
Have you cleaned the ground / chassie connections for the battery cable/strap?
Charge wire from the alternator good and not frayed or broken?
soundguy
No, it does not have external regulator.
I assume you are referring to the ground from the negative battery post. It looks to be in good shape including where it attached to the chassie.
Charge wire looks good from the alternator.
   / Electrical problems on Kubota M4900 #4
Reasoon I ask is I have had alts go bad where only 1 strand int he charge wire was making contact. thus alt overcharged on votlage and burne dout.. and battery was chronically dead.
soundguy
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A55315)
2012 UNVERFERTH...
2019 KUBOTA SVL75-2 SKID STEER (A60429)
2019 KUBOTA...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
