Electrical Problems
   / Electrical Problems #1
MT Montana
Hi all. I have a Montana 4944 that is having some electrical problems. Often times when it is started up, none of the electrical system works. No lights, no hourmeter, no tach, nothing. I usually will use it for an hour or two and then shut it off. Sometimes when I turn it back on, the electrical system will work, but the hourmeter doesn't show the use it has had. I bought the tractor new from a dealer about 130 miles away, and since then a new dealer has started up in my hometown, however, they are WAY too busy to deal with my problem, so Saturday I am taking it to the original dealer 130 miles away and leaving it for two weeks to get worked on. Has anyone experienced these problems or know a solution so I can get my tractor back sooner?
Also, the two front tires are showing serious checking with less than 50 hours. Montana has been very good about this, so if your tractor is still under warranty and you have bad front tires, you may want to call Montana corporate and tell them about it and you may be able to get replacement tires.
Also, my uncle has a 3840 that is a couple of years old and he is having problems with it overheating. Has anyone experienced this? Is there a fix for it? It is out of warranty so he is looking for a solution. Any help would be appreciated.
Thanks.
   / Electrical Problems #2
Could be a relay or maybe a new dash. Does your tach not work when the rest of the electrical does? It should be under warranty. Who is your original dealer? What area is he located in? The front tires are OTR. They had some curing problems in the front and it is only the R4's. Montana tried OTR and it was a bad deal. They remain with Titan tires and I am glad of that. We had about 20 sets of those OTR tires we had to replace.
Maka
Original dealer is GEI, and he is great to work with, just a long ways away. Nothing works when the electrical goes out, no lights or blinkers, and nothing on the dash.
   / Electrical Problems #4
My front windshield wiper doesn't work. I had some service work done at about 50 hrs and the mechanic took apart the dash because the hydraulics were leaking and flooding the cab. He didi something because now the wipers pop a fuse every time it is turned on. The mechanic acknowledged that he was at fault and he tried to find the problem before I picked it up but couldn't, so I took it and don't have use of my front wiper.
2005 PETERBILT 357 TRI AXLE DUMP TRUCK (A52576)
2005 PETERBILT 357...
2020 GP Equipment 24in Excavator Bucket (A51691)
2020 GP Equipment...
2014 Chevrolet Cruze Sedan (A50324)
2014 Chevrolet...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
