Electrical qustion
   / Electrical qustion #1
jack707
Veteran Member
up North wisconsin
farm trac 555
I have to install two pumps for my osb I have one power source but I need another outlet on the other side so I need to run a jumper from the live power to the outlet I will be putting in so what gauge wire do I need?.
   / Electrical qustion #2
If less than 100ft and 110v 20amp you can use 12 gauge.
OK when you open the door to the boiler on the right side there is power and the pumps have a power cord so instead of digging to nurroe lines I just want to run a wire from the live wire to the other side of the door so I CAN plug the pumps in.
   / Electrical qustion #7
Rambling incoherence, just as a start?
Well man if you can't understand what I said just forget it guy.
   / Electrical qustion #9
To figure wire gauge needed, we need to know volts and amps of the pumps, not the room arrangement. :)
Bruce
   / Electrical qustion #10
Jack,
I think Rock means what is the length of the wire run and what are the amperage of the pumps. Will the pumps ever be running at the same time, etc. Otherwise there is no way to help you with your question.
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
Ford Tractor (A50120)
2001 Freightliner E-One Pumper Fire Truck (A52377)
2001 Freightliner...
2015 Chevrolet Silverado 1500 Pickup Truck (A53422)
2015 Chevrolet...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2016 CATERPILLAR 325FL EXCAVATOR (A52705)
2016 CATERPILLAR...
