Chuck52
Veteran Member
Saturday, the Fourth of July, with family coming soon. So of course the fifty eight year old copper drain pipe under the kitchen sink decides this is the perfect time to spring a leak. This section of pipe is about 1.5 inches diameter and maybe a foot long. Goes to the second sink and is soldered in. A two inch crack opened in the bottom of the pipe and you can feel that the whole bottom is thin. So.....how to do a quick temporary fix? Fortunately, the local Ace hardware is open until 5PM today, and they have a real plumber (or at least a knowledgeable guy) to answer my questions. He pointed me to an epoxy tape that I had never heard of. Properly applied, it will hold 100 psi of pressure, so I figured it would work at drain pressure. Just to be thorough, I also used some of that putty epoxy tp make a patch over the actual hole and to reinforce the bottom of the pipe for several inches. I then wrapped about eight inches of the pipe with the tape. This stuff may be the next duct tape! Assuming it holds anyway. It is a bit difficult to wrap really long stretch like I did, because you have to remove the backing and apply it with a good stretch to activate the epoxy, but it makes a nice patch. I then went to Wally World for some wine, in case the tape didn't work. They had another brand of the same tape for about $5-6 vs the $13 at Ace, but I would never have known about it without the Ace guy, so I'm happy....and I bought the WallyWorld tape just in case! It can also be used to make grips for tools and is good for some electrical repairs!
Chuck
Chuck
