Mowing Engaging mower PTO
   / Engaging mower PTO #1
diesel_nut
Tennessee
~'88 1872(sold); '08 GT2554
GT2554
I guess it mentions this in the manual and I will look but this site has been dead lately so I will post this.
Should the mower deck be down when engaging or does it make a difference? The reason I ask is, I went to engage it yesterday and the engine bogged down a lot(deck was fully up). I put it down and there was no problem.
Also it seems to bog more when the tractor is first started and not afterward......so I'm thinking I must be doing it with the deck up most times when I first start out.
Manual says to raise deck fully (or be in short grass when deck is down) then engage PTO. Throttle set at "half way". Hmmmmm. I engage it on the driveway usually.
Maybe I need to let it warm up more before I engage it.
   / Engaging mower PTO #3
Dito,diyto,etc.
Yeah deck up,no tall grass under it, like the man said.
But one thing you need to do[ain't saying you don't,but],you need to let motor warm up for 5 min or so before trying to engage deck.
Oh, i said I didn't already :)
   / Engaging mower PTO #5
Hum,than,don't know to let a thing warm up a little before going,man!
Guilty as charged ;)
   / Engaging mower PTO #7
Well,from now on,your an expert!
   / Engaging mower PTO #8
Engaging on concrete is OK. It's easier on the PTO clutch if it is engaged with RPM's down. I won't beat the warm up factor.
That is also why I disabled the reverse cutout. Not good to have that clutch kicking in and out.
Can you say..........RevTech :)
2025 Wolverine EX-66-78L Pallet Fork Extensions (A47484)
2025 Wolverine...
2017 Chevrolet Suburban LT 4x4 SUV (A44572)
2017 Chevrolet...
Lennox T-Class HVAC Unit | High-Efficiency Commercial Heating & Cooling System (A46877)
Lennox T-Class...
2014 BBA PT-90 T/A Towable Piston Dewatering Pump (A44571)
2014 BBA PT-90 T/A...
Southbend Double Oven (A45336)
Southbend Double...
2008 Ford Explorer XLT SUV (A44572)
2008 Ford Explorer...
