Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,057
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
We've got an IH 886. Runs like a watch. Cutting a flat field several weeks ago, got a rear flat (dang it....)
We put onto flatbed & took to co-op. Tractor returned today. While I've been cutting the farm, I DO keep notice of dash gauges, temperatures and the like.... NEVER while me using this, has it overheated.
Radiator was full with nice green stuff
(historical information)
Today, get tractor back, brother in law...on a whim...checked engine oil. Seems was over full...
Checked radiator and it was essentially empty.
We drained the engine oil and then refilled the radiator... we ended up having a slow drip of "oil" coming out the drain plug. The first batch of 'oil' had already come to a 99% halt until adding water to the radiator.
So, those are the basic facts and other than the oil drain plug, not a single bolt was loosened or otherwise, taken apart.
Presumed diagnosis is, either through overheating (which again, I don't think ever happened) or perhaps through age (??) we're thinking the sleeves in this thing have broken their seal.
He told me this has wet sleeves in the cylinder and the sleeves had rubber O rings to seal the seperation of water and oil. We're guessing that either the engine overheated, perhaps hit a "hot spot" in the engine (for what ever reason) or maybe... one of the gaskets simply gave out from being 30 years old.
What I'm wondering is, given the above tidbits alone, since that's all I currently have.... does that sound reasonable?
If so.... how hard/expensive might it be to fix the sleeves? I presume we should replace all six instead of trying to find a bad "one" and maybe have future problems. (I'd rather spend more now to insure a full fix)
Can I do this while engine is mounted? The drain pan looks to be 100% removable from the underside so I'm thinking it can be done in the field.
Any special tools needed to pull the sleeve?
If we go this far (we might just sell the tractor as is) and decide to fix this, would it make sense to also do a valve job and new crank bearings at same time?
does this also typically involve new pistons & at minimum, rings? I'd suspect rings at minimum...not sure what I think about pistons.
Thanks for any thoughts
Oh....could it be something ELSE if not the sleeves?
