Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job?
   / Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job? #1
donpeak
New Caney,Texas (Houston area)
Zen Noh ZL 1501 with loader and Modern brush hog
Zen Hoh.........like a Kubota 175. two cyl 17 hp. diesel
black smoke out of engine upon starting........Starter just went out due to oil in starter..... previous owner said it had some Blow By--
Rings or worn cyls i guess
How much trouble is it to do a ring job and re-bore on this? estimated cost by average type of mechanic. My local car/truck mechanic fixes my outboard motor, car, truck,etc. with no problems and he said he has worked on tractors before. (he can re-build a Ferrari engine too)
These little tractor engines are new to me. Any one out there with previous re-build experience that could tell me if its a major problem. I am close
to Houston and down the street from a big auto machine shop. thanks! don peak
   / Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job? #2
Re: Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job?
Oil in starter caused by rings , Ferrari mechanic , black smoke and a machine shop down the road , should not be much trouble at all .
   / Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job? #3
Black smoke is not blow-by, black smoke is an over fuel condition not unusual at start-up. Twenty seconds does seem a little long though, possibly some leaky injectors. Bluish smoke is what you will usually see with blow-by. As far as oil in the starter I would say the most common cause of this is a bad oil pressure switch which is usually right above the starter. The switch leaks and drips oil on top of the starter and the oil seeps in. A really bad rear main seal or front transmission seal can do this too.
Brian
   / Engine has "blow by"......smokes for 20 seconds upon starting....Ring Job? #4
i'd agree on the oily starter.
ditto on black smoke at startup.
a few seconds is 100% normal. a lil mor eon a cold NA diesel , as long as it starts easy, takes fuel fine, and clears up after them 20 seconds.. I wouldn't worry at all.
JOHN DEERE 17P LOT NUMBER 227 (A53084)
JOHN DEERE 17P LOT...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
2023 Globe Booster Flipaxle (A51572)
2023 Globe Booster...
Polaris Sportsman 335 4x4 ATV (A51573)
Polaris Sportsman...
2019 International DuraStar 4300 Service Truck, VIN # 1HTMMMMN1KH714519 (A51572)
2019 International...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
