• Thank you for participating in the Summit Tractors Community. Per special arrangement with the TBN team, Summit Tractors will regularly monitor and contribute to this forum to help ensure that the community has direct access to Summit. You can ask and find answers to a range of topics directly from Summit and from other TBN users, including; Where to Buy, Future Retailers and Locations, Financing, Compatible Equipment, Tractor Operating, Equipment Specifications, Parts & Service Support, Warranty and anything else that may assist those in the market for a new tractor. If you cannot find the answer to a specific question on this forum, please feel free to contact Summit Tractors Directly or through a Private Message to Summit Tractors Support via TBN.
Ad top of page
Engine leaking oil
   / Engine leaking oil #1
Karlibob
2025 Summit TX25H
I just purchased a TX25H this week. I’m happy with the performance but I have had a couple of issues. The first was the 3 point hitch would not operate. I contacted Summit and they were quick to help with a solution. The travel lock valve was frozen. I had to remove the cover plate who’s was removing the know, removing 2 bolts and 3 plastic push pins. I used a pair of pliers to rock the flexible line back and forth and it freed up and the 3 point dropped down and is now working. The rep thought that was the issue up front and turns out he was right. Second issue is that I have a drip under the engine and over the last 24 hours it has turned into a small puddle. Has anyone experienced this?
Typos above.
I had to remove the cover plate by removing the valve knob and then I removed the bolts and push pins.
I’m not sure why the above text happened the way it did.
CATERPILLAR 259D SKID STEER (A51242)
CATERPILLAR 259D...
Woods 3 pt RM 550 Finishing Mower (A50515)
Woods 3 pt RM 550...
International 3788 2+2 (A52128)
International 3788...
Kubota L503OD 50HP Utility Loader Tractor (A50322)
Kubota L503OD 50HP...
2001 GREAT DANE 53' CONTAINER TRAILER (A51243)
2001 GREAT DANE...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Ad bottom of page
