Engine Problem
   / Engine Problem #1
joshatfarm
We have a case IH 895, and we have just had to replace one of the big end bearings, was running fine after but then soon lost power, loud knocking noise, sounds like its down on a cylinder, pouring out black smoke and sparks coming out of exhaust, seems to be igniting in exhaust, took head off again and pistons and valves look fine, can anyone suggest any ideas?
   / Engine Problem #3
I have been told by a mechanic if its white smoke its fuel if its black its oil. Take the oil pan off and see if any thing came loose.
   / Engine Problem #4
Should have left it together and first try cracking individual inj lines to find affected cylinder. One which makes no difference in performance is bad one. Then you can swap that inj with another cyl and see if problem moves with same test. Most likely just dribbling inj or delivery valve problem. If delivery valve, problem will stay in same position.
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A49461)
Miller and Smith...
KSI Conveyor (A51039)
2000 GMC C7500 ANCHOR DRILLING TRUCK (A50854)
2000 GMC C7500...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
