EP-90 Gear Oil
/ EP-90 Gear Oil #1
regor66
Aiken County South Carolina
John Deere 790
I bought a Speeco phd at TSC today. The transmission comes without oil. The owners manual says to use EP-90 lube oil. I've searched the world over without a solution as to what to get. I called Speeco and they could not tell me what to get either. When I didn't accept this they took my number and called me back. They guy actually told me they called TSC and TSC recommended something I've already forgotten. Anybody have a suggestion? I also called Mobil Oil and the tech asked if it was Gl-4 or Gl-5. I'm familiar with those but don't know what to use. I'm a little put out that the manufacturer couldn't supply me with the info. Kinda makes me wonder if the unit is quality built.
/ EP-90 Gear Oil #2
You should be able to use a SAE 90 oil which is a GL5. I use a Royal Purple synthetic oil in a 80W90 and it is also a GL5. I was just at Advanced Auto Parts and they had the SAE 90 and so did Walmart. I use the 80W90 in all the gear boxes and change it once a season in the snowblower and the mower gear box.
/ EP-90 Gear Oil #3
Any auto store should have EP90. It's what gets put into auto differentials. Every auto I've ever been in had it.
/ EP-90 Gear Oil
The question in my mind is the Gl-4 or Gl-5. From what the guy at Mobil told me and what I read on google searches they are used for the same thing but different applications. Supposedly GL-5 has a high sulfur content and is not compatible with "yellow metals". Bronze, brass,etc. The Chevron Oil site has numerous warnings on using Gl-5 where Gl-4 products are specified and vice-versa.
/ EP-90 Gear Oil #5
</font><font color="blue" class="small">( I bought a Speeco phd at TSC today. The transmission comes without oil. The owners manual says to use EP-90 lube oil. I've searched the world over without a solution as to what to get.)</font>
The answer was right in front of you. On the oil isle at TSC.. there are quart bottles of both ep90 and ep190 gear oil.. they are traveler brand.. black bottles with the convienient little pointy nose. The look like a regular quart of oil...
I used the ep90 for my pto generator gear box.. etc.
Soundguy
/ EP-90 Gear Oil
Yep, You are right. Today I went to a different TSC from where I bought the PSD. Asked for EP-90 and the guy took me right to it. Just to satisfy myself I went to the other TSC and looked. Nothing. Asked the store manager, he looked and then looked in the computer. They were supposed to have it but didn't. Oh well. Thanks for the replies. Can always get help here.
/ EP-90 Gear Oil #8
I did a Google search for EP 90 and found this older thread! I bought a Speeco PHD at TSC and saw the instructions said to use EP 90 lubricant. My local TSC did not have EP 90 on the shelf. I asked a sales person at TSC, and they had no clue. I called Speeco, and they called back promptly and said I could use any gear oil. In fact, they said the gear box is such that you could probably use motor oil or grease, but they recommend gear oil.
Since it will only take a quart or two and will not need to be changed often, I am taking a friends recommendation and spending a few extra bucks for Mobil 1 gear oil.
/ EP-90 Gear Oil #9
i'd dump in some 75w90 syn from a quart bottle.. though any generic 80w90 or 85/140 would do.
soundguy
/ EP-90 Gear Oil #10
BXTotal;
I too used to think about biodegradable oil but then I figured that I would not be putting the oil, new or used, into the environment. All my used oil goes into the recycling tank at the county facility. I'm wondering why you are thinking of biodegradable oil. Or are you contemplating bio sourced oil? Just wondering....
SimS
/ EP-90 Gear Oil #11
Hi SimS,
Hit the wrong button. Posted to the wrong thread. I moved the original question to a new thread.
/ EP-90 Gear Oil #12
I just run 80W90 gear oil in my PHD, Bush Hog, and Finish Mowers gear boxes. I have not changed the PHD yet and I have had it for 5 years now but it probably only drilled 100 holes. The BH gets it every other year and the Finish Mower at the end of every season but I use it a lot, about 75 hours a year.
Chris
/ EP-90 Gear Oil #13
I put some moly disulfide mixture in with any place i put gear oil, FWIIW. No problems either way in decades.
Mike
/ EP-90 Gear Oil #14
I'm sure there are EP 90 straight grade gear oils sold. Normally though, you will find 80W/90 in GL-5. Gl-5's are for steel gears on steel gears, the EP additives arn't corrosive on steel, like they would be on brass or bronze gears after the oil heats up in use. Straight 90 grade gear oils that I usually see, are called mineral oil 90, a GL-1 type that would be suitable for yellow metals. Fuller Transmisions are an example of a GL-1` in 90 grade application in lieu of 50 grade motor oil or synthetic 50 tranny oil.
/ EP-90 Gear Oil #15
lately it has been easy to get 80w90 gl5/mt1 oils that are yellow metal safe... I liek that because some of the 90wt gl1/3 oils are getting harder to find thru regular supply routes.
napa still has gl1 90 under 65-205 #.. but tsc stopped carrying their ?gl3 equivalent.
soundguy
Kenworth T6 (A63688)
DOBBS 48in Forks and Frame Skid Steer Attachment (A61572)
DOBBS 48in Forks...
UNUSED WOLVERINE HYD SNOW PUSHER (A64281)
UNUSED WOLVERINE...
2026 Kearney 96"x 24' Gooseneck Trailer (A64119)
2026 Kearney 96"x...
UNUSED WOLVERINE SB66-66" ROCK BKT (A64281)
UNUSED WOLVERINE...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
