Evaporation rate
   / Evaporation rate #1
bcarwell
Austin, Texas
Kabota 7500DT
Anyone know what a general ballpark evaporation rate is for a pond in Texas (presumably as a function of temperature). In other words in the 90-100 degree range, is it X gallons per square foot per hour, and at 80-90 degree range, Y gallons/sq.ft./hr, etc. ?
I realize this is a function of many other variables- wind, humidity, etc., but what are some <general> ranges ?
Farmer Bob
   / Evaporation rate #2
Farmer Bob,
Search TBN for a similar discussion. Someone just asked this with in the last month or two. Sorry but I don't remember where this was discussed nor the answer but the topic did just bubble up.
Later,
Dan
   / Evaporation rate #3
I remember the conclusion was - based on a scientific research - the evaporation depends mainly on the direct sun hitting the water.
Do a search, it is somewhere around here.
   / Evaporation rate #4
Generally you should be looking at between 1/2" and 1" a day during hot dry days in the Texas sun.
One unscientific but fairly accurate and easy way to test would be to put a water tight bucket next to the pond and see how much it evaporates.
One other factor is how much plant life there is in the pond. Plants can use a lot of water.
2007 FORD F-550 XL SUPER DUTY DUMP TRUCK (A51406)
2007 FORD F-550 XL...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
2007 International 4300 Box Truck, VIN # 1HTMMAAL07H360176 (A51572)
2007 International...
2021 Ram 1500 Bighorn (A53472)
2021 Ram 1500...
JOHN DEERE 1725 CCS (A53084)
JOHN DEERE 1725...
