everyone was right
/ everyone was right #1
oledocward
north carolina
kubota 2350
Changing to Rotella made no difference in the operating temp of my BX2350. I mowed yesterday in 85 degree weather and as usual the temp indicator on the tractor raced well above normal. As Big Bubba suggested, when I finished, I turned the tractor off and CAREFULLY removed the radiator cap. I immediately checked the water temp with a laser thermometer. Multiple reading showed it to be between 173 and 179 degrees--NORMAL, although the tractor instrument still showed it to be quite high.
Now I can run my tractor in peace without keeping one eye on the temp gauge. As sereral of you have stated, the Kubota instrumentation (temp, fuel, etc.) only offers a vague suggestion of the reality it is supposed to measure. Thanks again to all who advised on my first thread.
oledocward
/ everyone was right #2
For just a few bucks you can buy a mechanical tempature gauge and be sure of where it's at all the time. With mowing and bush hogging, it's just a matter of time until the radiator gets pluged up. When my tempature gauge starts to rise, I stop what I'm doing and clean off my radiator. Depending on what I'm doing, I might have to do this fairly often. It's really important to have a reliable tempature gauge on your tractor.
Eddie
/ everyone was right #3
I agree - If you know that your temp guage is inaccurate then I would supplement it with a good one. The last thing that you want to do is overheat your tractor and put that investment at risk. The add-on guage is VERY cheap in comparison to the engine. ;)
/ everyone was right #5
a relief for you that it's just an inaccurate gauge not sure if after market temp sender units have a universal thread, imagine they do....just be sure not to force threads on the head if they don't mate up (pardon my caution, am sure you realize this) you don't want to mess up a thread on the head (or is it the block?). next question would be to go either mechanical or electronic. having degree readings is handy and helped on my old massey 35 hogging in fields w/lots of airborne debris think most thermostats open fully at 185. bb
/ everyone was right #6
/ everyone was right #7
Where did you hear changing the oil will make it run cooler? Oil is not really there to do the cooling.
there were a couple of posts on this webb site that made the observation that thier engines ran cooler with the Rotella 10W40; I believe I searched "Rotella."
/ everyone was right #9
If you do a search of diesel engine tech articles from different sources including diesel mfg's and oil mfg's, you will note that in almost all diesel engines there is a cooling oil jet against the under side of the pistons. This is to cool the piston head and skirts as these areas run much hotter than gas engines because of the much higher compression ratios ( remember these are compression ignition engines) and the desire to extract as many BTUs from the fuel. The higher the combustion temps the more energy from every pound of fuel. (at $4.50+ / gal this is a good thing)
Shell Rotella is an excellent diesel rated oil, I run the Rotella 15w40 full synthetic with excellent results. Synthetics typically will help an engine run cooler, especially if there is an engine oil cooler.
/ everyone was right #10
Just curious if replacing the sensor might not be your answer. Mine shows it about a quarter way off the bottom when normsl temp. If it gets up I know the grill is plugged. It stopped working once but the wire had detached itself.
The sensor might be the problem; as I stated earlier, my dealer said that the sensor is located too close to the exhaust. As I regularly clean the radiator, screen, etc. and check the water level, I just plan on checking the temp gauge, without obsessing, and if it runs hotter than "normal," which is marked with a scratch on the face plate of the gauge (at about 10 o'clock), I will stop and investigate the problem. I also plan on checking the feasibility of installing a new gauge and sensor.
The good thing is that I know the tractor is not running hot!
Thanks to all for good, sound advise.
/ everyone was right #12
oledocward
!! Did you use the correct emissivity for water/antifreeze? I dont know what the value is but Im thinking it is a good bit less than 1. If your IRTmeter used 1 as a reference it calculated a T below actual. Unless you know the E of the fluid it would be better to take the measurement of the top of the rad or the top hose near the rad. These E's will be near 1.
larry
/ everyone was right #13
This is true. The engines I rebuilt actually had the spray nozzles, I don't see these on the Kubotas. I didn't see them on any parts list. Some cases there is a hole on top of the connecting rod where oil is slung out from the crank journal, other cases (ours perhaps) oil is just slung from the rod journal onthe bottom side of the piston. I haven't removed the pan on mine yet to see what's inside...yet. :D
But I guess my question is why would one oil produce noticable more cooling than another. And if if did, would it be that noticeable (5 degrees, 10 degrees, etc). Of course if it's time for an oil change...what the hay!! :D
213097 (A64276)
213097 (A64276)
Coleman Go Cart, 2 Seater, Gas Engine (A65640)
Coleman Go Cart, 2...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2022 CATERPILLAR D3 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
2015 Hyundai VC2530152 53ft. T/A Dry Van Trailer (A64556)
2015 Hyundai...
Worksaver 3 Point Post Hole Digger (A65640)
Worksaver 3 Point...
