Exhaust Leak
   / Exhaust Leak #1
ym2610
Stevenson, Alabama
Yanmar 2610
my 2610 has a exhaust leak at the head, I know it just need gaskets, but my question is will the studs break off, they look very rusty on the ends, has anyone took their exhaust manifold off and did the studs break, do I need to have the manifold surfaced, or and most cases will just the gasket fix the problem. Thanks Robert
   / Exhaust Leak #2
Both questions will be answered when you remove the head.
Do you have the drill and taps for removing a broken stud?
Egon
   / Exhaust Leak
Yeah your right, I wish I had thought of that. /forums/images/graemlins/grin.gif LOL
   / Exhaust Leak #4
No one can possibly tell you whether the studs will break, or if the manifold needs to be re-surfaced, but I would soak the studs in "PB Blaster" for a couple of days before trying to remove them.
   / Exhaust Leak #5
I would get the tractor hot first, stop the engine, spray the studs and nuts with rust solvent, and let it sit like that for a couple of days. Start the tractor and get the engine warm again, spray with rust solvent again, and with the engine sill warm, try to loosen the bolts. Some parts that are rusted come apart much better hot due to the expansion of the steel with heat. Might still break the studs but your chances are much better this way than cold.
Chris
   / Exhaust Leak
Thanks Chris, I hadn't thought about that, sounds like a plan. Thanks Egon and yes I have the drill and tap if they do break, if not some real good shops around, but I did like your answer. Thanks Norm, I know it sounded like a dumb question, but what I was wanting to know if any of the shops that work on them or anybody else has had problems, like if you call me and ask about a quick disconnect fitting for the heater hose on a small block Chevy and some V6's, I can tell you yes its going to break and how to get it out, but thanks anyway, any info is good info. Robert
   / Exhaust Leak #7
For a first attempt I would try just replacing the gasket, perhaps using some hi-temp gasket cement. It might last many years before you need to take the manifold in and get it surfaced.
FWIW, on mine the manifold bolts unscrewed easily like new equipment despite looking old and rusty.
   / Exhaust Leak #8
I almost hate to recomend it..........
If you have a sealing problem at the manifold. A good silicone spread "thinly" on the gasket will help to make up for the imprefections..... Just please, if you do this, follow the "little" recomendation. I cant tell you how many components I have seen that have been sealed on with 2-3 tubes of orange silicone /forums/images/graemlins/blush.gif(can you guss the brand). Some guys just believe that if a little is good a whole lot must be great..
Just for recerfence, the best silicone I have ever used is Ford Diesel Silicone, I Forget the part number but the parts guy will know what it is. It comes in a caulking gun type tube. This stuff is used for everything and will seal everything. Dont get it on anything you dont want it on, including your skin. Its tough to get off. If you over do it, you wont get the parts apart again, so just skim it. /forums/images/graemlins/grin.gif I have used it on anything from exhaust pipes(for a quick fix) to gluing things together, shoot you could probably build a boat with it and trust it to cross the Atlantic /forums/images/graemlins/grin.gif
   / Exhaust Leak
Thanks California, I had thought about that. HGM I'm a Chevy guy I can just hear the Ford guy, but if it work a can listen to them make fun of me for using Ford products, if I don't have to do it again it will be well worth it. already had to use a Ford brand antigell, local walmart never had any thing smaller than a gallon of power service. anyway Thanks for the info everybody. Robert
   / Exhaust Leak #10
I have replace the manafold on my 2020. and have worked on many exhaust systems on cars and tractors. Brush the stud bolts with a wire bruch and then use some pb blster if you like. The studs on my tractor came off well. They screw in to the head just like a bolt. If the nut will not come off it will screw out just like a bolt. If it seems too require too much tork to remove it use a hand impact wrench and tap it a few times. Unless the tractor has set in the rain with the hood off you should have no problem.
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
2019 TAKEUCHI TB230 EXCAVATOR (A51246)
2019 TAKEUCHI...
POWER LINE 180 LOT IDENTIFIER 82 (A53084)
POWER LINE 180 LOT...
2016 Ford F-350 Ambulance (A51692)
2016 Ford F-350...
2013 Caterpillar 950K Articulated Wheel Loader (A51691)
2013 Caterpillar...
(3) UNUSED MR HEATER PORTABLE PROPANE AIR HEATER (A51247)
(3) UNUSED MR...
