Exhaust Modification On A Kubota L3240
   / Exhaust Modification On A Kubota L3240 #1
Sassi
Perry, Georgia
Kubota L3240
My Kubota L3240 has the exhaust outlet on the left side, discharging almost directly across onto the left wheel area. This may seem to be OK to some, however when I am working in soft dirt, the left wheel does pick up enough dirt such that the exhaust causes the dirt to be sprayed upward and the dirt cloud comes back into my face.
It appears to me that if the exhaust is redirected slightly forward, and away from the left wheel vicinity, that this issue might be resolved. Is this something that others may have already devised a solution too? I am sure that I can get a machine shop or a company that specializes in exhaust systems to fabricate a piece for me, but has anyone found a simple, cheaper solution to redirect the exhaust flow?
   / Exhaust Modification On A Kubota L3240 #2
I have seen them routed up along side the hood. A 90 and a piece of pipe was all it was. Looked odd but it worked I guess.
   / Exhaust Modification On A Kubota L3240 #3
Just put an exhaust tip on the pipe that redirects it. A lot these are available at auto part stores. Clamps on with built in screw
BOMAG BW213 SMOOTH DRUM ROLLER (A58216)
BOMAG BW213 SMOOTH...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A56436)
Michelin CARGOXBIB...
2012 NISSAN ALTIMA (A58214)
2012 NISSAN ALTIMA...
2017 Dodge Charger Sedan (A56859)
2017 Dodge Charger...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
