Exhaust Pipe Rain Cap
   / Exhaust Pipe Rain Cap #1
MMH
Murrysville, PA
JD 4500
My B9200 has the exhaust pipe that goes strait up. The tip is cut such that the exhaust pipe opening is perpendicular to the ground. When rain falls the slightest breeze will allow rain to drop in the pipe. My tractor is parked outside & I try to put a coffee can on the pipe when I'm not running it. Is this necessary? Would the muffler keep the rain from running into the engine?
   / Exhaust Pipe Rain Cap #2
Definetly not, get a flapper cap for it, you'll forget the can one of these days and next thing your engine will be full of water.....Mike
   / Exhaust Pipe Rain Cap #3
The ole coffee can has been used about as long as there have been tractors. As kids, for entertainment, we always watched to see how high the D-John Deere would blow it into the air when the first cylinder fired.
You could cut the pipe square and add a rain/weather cap and in general they do a good job but the can is a sure thing.
The muffler won't stop the water and water in it will surely make for faster rusting out.
If this was my tractor I'd be covering a few other things like the instrument panel, steering wheel and seat. In the good ole days that wasn't necessary as the sun and rain didn't effect cast iron much.
   / Exhaust Pipe Rain Cap #4
The fun part was to try to catch the can on the way down (from the seat)! :laughing: ~~ grnspot
   / Exhaust Pipe Rain Cap #5
Some people don't like the sound of a flapper flapping, but with the noise any diesel tractor makes, the extra sound (rattle) of a flapper didn't bother me at all. I bought one for my B7100 at Tractor Supply Company where they had a variety of sizes.
That is my concern. I do put the coffee can on, but sometimes forget. More concerned about rust than engine filing up w/ water.
   / Exhaust Pipe Rain Cap #7
I used to have a B8200 with same exhaust set up. I found a piece of tubing to fit over the pipe, bent a 90 degree curve in it and cut tubing off about 2" beyond the curve. No pictures, sold the tractor.
   / Exhaust Pipe Rain Cap #8
I've used the flappers on the big tractors and automatically picked one up when I got my little Yanmar. The pipe is at eye level and close and I was getting sick from the exhaust. I took it back off and have no problems. I park it in the shed but keep a soup can on standby if I get caught out in the rain.
   / Exhaust Pipe Rain Cap #9
My LS is the same way with a 45 degree bend and then a 45 degree cut. The bend starts below the cab but ends above it. I dont think I could just cut it straight as then it would likely put the exhaust right into my cab windshield. Since I shed mine all the time, I am not concerned with it, but I would think that the manufacturer would take that detail into consideration and make allowances for it setting outside. They may have some sort of drain hole in the muffler like car mufflers do to allow any accumulated water to leak out. Unless you hit it with a fire hose, it shouldnt get a lot of water in it anyway, certainly not enough to flood the engine unless it was exposed to another NOAH's flood.
   / Exhaust Pipe Rain Cap #10
I never had one on a compact tractor, but I would think you'd never hear the flapper if you kept the RPM up about a thousand.
The old Deere compacts (670, 770 and 790) exhausts had some kind of rain trap. Not sure how it worked...read about it in the service manual, IIRC.
John Deere 1025R 4x4 Tractor with Loader (A44391)
John Deere 1025R...
2016 GENIE GS-2632 (A45046)
2016 GENIE GS-2632...
2003 Mack MR688S 58 Meter Putzmeister Concrete Pump Truck (A45336)
2003 Mack MR688S...
2008 CAT 277C Skid Steer (A42203)
2008 CAT 277C Skid...
2018 John Deere 5075E (A44501)
2018 John Deere...
2019 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A44571)
2019 International...
