F/P 2425 running 5 ft bushog with fel on.
   / F/P 2425 running 5 ft bushog with fel on. #1
texman
Hey guys, i used my bushhog the other day and it did a pretty good job. I was just curious if I should take the fel (koyker 160) off prior to using the hog and for what reason if i should?
thanks
   / F/P 2425 running 5 ft bushog with fel on. #2
Only if it gets in the way, you can drop it a few inches off the the ground and use it to find obsticals before your mower does. but if you have to work near fences and such, it might get in the way and be better removed.
   / F/P 2425 running 5 ft bushog with fel on. #3
It makes a nice counterweight for that 5' deck:) I use mine as chip mentioned down low and at a crawl to find obstacles when busting heavy brush.
once again thanks for the good input. much appreciated
STORAGE FEES (A54607)
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2016 INTERNATIONAL DURASTAR 4400 (A53843)
2016 INTERNATIONAL...
