FAE DML/SSL 150
   / FAE DML/SSL 150 #1
mactrade
weslaco, texas
Massey Ferguson 573, Bobcat T 650, Landpride 4188, Bobcat Root Grapple. Brushcat
I just got a quote (19-20K) for a FAE DML/SSL 150 for a Bobcat T650 (74hp) hi-flow 30.5 gal/min and wanted to know If any one has any comments on the set up. The primary use would be South Texas (Hidalgo, Cameron, and Star area) brush and mesquite 3-5 inch. Any input would be greatly appreciated.
   / FAE DML/SSL 150 #2
Sure yellow dog will chime in but I would think that for full time use it would be somewhat under powered
   / FAE DML/SSL 150 #3
I had to look at the specs. That setup is about where I was 10 years ago.. except I had a single speed mulcher on an s300 that put out just over 30 gpm and not quite the same psi or nearly as efficient hydraulic system as the 650 has now. I think for what you are doing, with the variable torque motor, you will be okay but you are on the lower end and the motor will work hard to keep the pump up... at least that's what I can envision. I would have to check the badge on my 150 but if you are on the low end of the spectrum, I'd look at a 125 vt but with the 110cc motor versus a 65cc in case you end up upgrading machines.. That 125 or a 150 vt can go up to 40 gpm machine.
The 65cc motor in the new dml vt is slightly larger than my old 125 which, I think, was 63cc. Variable torque is definitely worth the extra money and if you get some cobra teeth it will work even better for you.
You will need a lexan door and debris kit.. not sure if the 650 has that kit but without it, you will have greater fire damage since these M series machines move a lot of air for cooling.
Do you already have the 650? If not, get at least a 750 or 770. Feel free to email me if you have any questions on how I set up my Bobcats.
   / FAE DML/SSL 150
Thank you for the replies and the information. I will send an e-mail.
2023 FG INDUSTRY STE 35SR MINI EXCAVATOR (A51222)
2023 FG INDUSTRY...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52128)
New Lewis Brothers...
Gleaner R50 Combine (A50514)
Gleaner R50...
Walking Floor Trailer 43ft (A50322)
Walking Floor...
2016 MACK TITAN TD713 (A51219)
2016 MACK TITAN...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
