fan freezing up B 7100hst
   / fan freezing up B 7100hst #1
cbpete
Cub Cadet Yanmar 2400
Is there a problem with the alt. or is something else happening. Just trying to learn a little fixing but not to good.
   / fan freezing up B 7100hst #2
The Dynamo bearings may be worn out. :confused::confused:
Do you have a PDF showing all the parts? If not send your email and you will receive one.
   / fan freezing up B 7100hst #3
First off welcome to TBN.
Does the fan turn at all?..if so call you hear high pitch noise or grinding sound if so not good.
Have you check the belt for wear or slack?
   / fan freezing up B 7100hst #4
I am with Egon. Try to take the belt off and spin the dynamo/alternator with hand. I had the bearing go bad and the belt eventually stopped and burned apart.
You can tell if the bearing is good or bad by turning it by hand.
no I don't have the pdf
my email is cbpete1@gmail.com
I also have the fan off and dynamo will move but very hard to turn at all, the fan belt is approx 2mo old and still good shape
thanks
   / fan freezing up B 7100hst #6
The PDF's are in the mail. Let me know if you don't get them.
Suggest taking Dynamo apart. If the bearings are bad you may be able to replace them and not have to purchase a new alternator.:)
[Lubing them and hand turning may work but there is a good possibility they are damaged]
   / fan freezing up B 7100hst #7
To remove dynamo it may be easier to remove hood, oil cooler and radiator.
On the dynamo there will be one well placed nut/bolt? that is difficult to get at. Bend a wrench to fit or, as others have done, use a ratcheting boxend.:D
Thanks again for your help. I got new bearings for the dynamo but forgot to order new gasket so I had to wait. got everything put back together and it is working fine, much cheaper than new dynamo. sure hope it lasts I don't look forward to putting that nut on the bottom on ever again. I don't know how you do it, I ended up putting enough grease on the nut that it stuck on the stud (finally) and was able to to get it started. I'm keeping that wrench you told me to bend just incase.
thanks again.
   / fan freezing up B 7100hst #9
It is fun getting that nut threaded again, isn't it! Blue air!:thumbsup:
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
LOT LOCATIONS (A51219)
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2019 Generac MLTS-1 2.4kW Towable Light Tower (A49461)
2019 Generac...
