FARM PRO 2420
   / FARM PRO 2420 #1
jerm47250
I HAVE A FARM PRO 2420 AND IT WILL START UP AND RUN AT AN IDLE BUT WHEN U HOLD THE THROTTLE WIDE OPEN IT ACTS LIKE IT RUNS OUT OF GAS THEN IF YOU PUMP THE BLEEDER PUMP A COUPLE OF TIMES IT WILL START RIGHT BACK UP. IT ONLY HAS 50 HOURS ON IT IF ANYONE COULD KNOW WHAT MIGHT BE WRONG I WOULD APPRECIATE IT.
   / FARM PRO 2420 #2
Shut off the fuel at the sediment bowl, then remove the fuel line between there and the fuel pump. There will likely be an inline screen at the fuel pump end. Clean it. Reinstall. If the problem persists, check the other flexible hoses for a similar screen.
//greg//
   / FARM PRO 2420
THANKS I WILL GIVE THAT A TRY
Electric Concrete Mixer (A51573)
Electric Concrete...
2022 Bobcat T66 R - Series Skid Steer (A51573)
2022 Bobcat T66 R...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
Loflin 72in Quick Attach Skid Steer Grapple (A51573)
Loflin 72in Quick...
2021 JOHN DEERE 8R 370 LOT NUMBER 188 (A53084)
2021 JOHN DEERE 8R...
90018 (A48082)
90018 (A48082)
